Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi WT-46807 Dead
Nothing at all. The power cord works. The little fuse next to the power cord attachment is good also. Any ideas. We had lightning the day it died.
  • 1 more comment
  • rysaarch Jul 05, 2008
    The LED does not light up at all. I already tried pushing those buttons and it doesn't do anything.
    Thanks
  • Anonymous Aug 07, 2008
    I have the same problem. I tried pressing the menu and input buttons both in together to see if the led would blink, but nothing happened.
  • Gregorry Jan 14, 2009
    hi
    I give to same expert and he say that is to be damaged parts board
    PCB 2HDW 211A36501 GCMK-MIX catalogue number of manual diagram is 935C908001
    I send email to service and nobody answer me.
    Do you nou where i find such a parts??
    My email- kedziorno1@wp.pl
  • 927 Answers
Good day; TRY THESE SOLUTIONS: 1. CHECK IC7A00 PIN 53 FOR LOW LOGIC (0 VOLTS), IF HIGH (3.3 VDC) CHECK FOR SHORTED D9A31 PART # 264P045050 AND OPEN R9A33 220 OHM 1/4 WATT ON THE POWER PCB. This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. I hope this more helpful, big IRISH.
Posted on Aug 12, 2008
  • Mitsubishi Master
  • 8,617 Answers
Does the led light up when power is pressed? If so press menu and input buttons both in together to see if the led will blink a two digit error code then let me know the results. Please respond to this same post.
Posted on Jul 04, 2008
How do I replace the fuses on a WT-46807 that protect the convergence circuit?
There are no fuses going to the convergence board, the converegnce IC needs replaced.
Aug 08, 2011 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi model Wt-46807 Power shuts down after turning on. Tried the solution of pressing the menu & input buttons at same time for at least 5 seconds. Power light error code was 2 blinks/pause 2...
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Oct 16, 2010 | Mitsubishi WT-46807 46" Rear Projection...
THE TV DOENT TURN ON COULD IT BE A FUSE
hello if there no power at all the it may be the glass fuse inside the located in the power supply if black in colour then it's blown but mmake sure you put the same rated fuse back in the value will be on the end of the fuse i'e 2.5amp. beware if you put another 1 in and it blows again the you have a dead short in the tv good luck
regards
shaun
May 08, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 Bottom of picture cut off
YOU HAVE A VERTICAL DEFLECTION PROBLEM, THE RETURN CAP IS DRYING OUT AND MUST BE REPLACED
Dec 27, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 won't stay powered up.
try giving the back cover a thump it may be dry jointed..
Sep 14, 2009 | Mitsubishi WT-46807 46" Rear Projection...
MITSUBISHI WT 46807
You have a power supply decaying; it will likely get worse. There may be board repair of this available so locate the power supply board - look at the assembly that seems closest to the AC cord, check the board number and search on it.
NOTE: There may be more than one number on the board since the bare board may have its own but it will be obviously a part of the board. The assembled board number will look much more temporary and may even be on a label.
If you locate a service company that claims the ability to service it, pick their brains a little since it may not be a main power supply failure but rather another, possibly separate board that produces the high voltage for the CRTs. If you do find a separate board that seems to be servicing the CRTs, note that board number too and ask them about both.
Sep 30, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807
MY FRIEND YOU HAVE A POWER SUPPLY PROBLEM AND MAYBE THE CONVERGENCE IC'S ARE BAD.THERE ARE A FEW TRANSISTOR IN THE POWER SUPPLY THAT HAVE TO BE REPLACED FIRST.
CAYPIANAN@YAHOO.COM
Sep 23, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Power trouble
You need a multimeter to diagnos the issue. I have one with the same problem that i had gotten for free. I found that two of the fuses that are soldered to the middle board are bad... i have not tried replacing them yet but i will repost.
Apr 19, 2008 | Mitsubishi WT-46807 46" Rear Projection...
WT-46807 HD PRoblems
GO TO INPUTS ON THE MITSUBISHI AND TURN THEM ON, THEY COME IN THE OFF POSITION
Nov 17, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
255 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
