I am looking for a ssb for a Philips 37 inch plasma television, the repair man quoted $900
  • 8,617 Answers
I will need the model number of your phillips in order to assist you. Please respond to this same post.
Posted on Jul 04, 2008
Philips tv 50pl9126d/37 help
Hello your problem is you have a bad color wheel that needs replacing.
Nov 09, 2011 | Philips 50PL9126D/37B 50" DLP TV
No sound, no picture` MAGNAVOX 51MP6500D/37
SSB board it is over next to tuner stands up behind it . Call Mats for Part 1-800-628-1118
Sep 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips 60PL9200D/37 has no display with new light engine/power supplt/lamp assembly/ and SSB
Did you change the lamp yourself or was it serviced,and when it was changed was the ballist(s) messed with? It may be the ballast that caused the problem to begin with.
May 09, 2009 | Philips 60PL9200D Projection Televisions
60 inch tv philips projection sonnd in and out
Audio amps in a Philips PTV is one of the easiest sets to repair. To my knowledge all the individual parts are still available so I see no need to replace the entire amp. know what problem you have first, then we'll try and determine what you may or may not need? They had a board which is called the SSB ( small signal board ) that used to go bad creating similar symptoms like that. That board is the size of a 3x5 photo and stands up on the left side of the chassis, anyway let me know?
Feb 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips 60 inch projection
The I2C message that you get means the Inter IC communication bus on the system board has gone bad. Replacing the IC would not solve the problem.Philips patented this technology to reduce the number of ICs on the systemboard.There would be a physical I2C chip on the motherboard.
You can read about the technology on the post by philips
http://www.nxp.com/acrobat_download/applicationnotes/AN10216_1.pdf
I would suggest update the firmware on the board, or try replacing the I2c interface controller chip.
Thanks
Proton
Jul 28, 2008 | Televison & Video
I need help tv plasma phillips
Hello gruponapa,
This problem is linked to a power supply issue. The SSB is part of the power supply chain and will cause system failure if the board is defective. I have seen to many of these type of modular power supply boards fail. The shutdown circuit is detecting excessive voltage, and in the process of turning off the set it may have blown something else. I am begining to suspect a design flaw, which happens from time to time. I would suggest having a qualified TV repair person take a look at the TV and work on it.
I hope this helps,
Thank you,
Shuttle83
Jul 27, 2008 | Sony KP-53HS30 53" Rear Projection...
Cant find a service manual or schematics for a philips plasma tv "42 pf9936/37
Need the chassis number and I may beable to locate one for you .
Jan 30, 2008 | Televison & Video
55 inch (55pp95 0217) turns on then clicks off
I believe what you have there is a Philips 55pp9502/17 and with hose symptoms it's most likely the Smd capacitor 2009 on small signal board is leaking. Replace 2009 using 319801634710. Locate 2009 on the flyback side of the ssb, above the marking for ic7011 which is absent. Caution: remove ac power for at least 10 seconds before removing the Ssb from the chassis.
If you're not that good with SMT (surface mount technology), like some of us techs simply replace the ssb as a module, Philips p/n# 310432815384...
Bill
Oct 31, 2007 | Philips 55PP9401 55" Rear Projection...
TV powering off by itself
The SSB board (small signal board ) Part # PH3912725871 or 313912725871 is most likely the problem. From the rear it is on the left side of the chassis mounted vertically in a socket similar to a computer memory stick. There is a small ribbon cable that pluggs into it. You can try to re-seat the board after cleaning the contacts with a pencil eraser. It may help out but most of the time the board needs to be replaced. You wont like the price, They are over $200 and there is a $100 core charge.
Oct 25, 2007 | Philips 50P8341 50" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
