Question about Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony trinitron wont turn on the standby light blinks 2 times
  • teri533 Aug 10, 2008
    I have the same problem. We have a 2002 Sony Trinitron Wega. It keeps shutting off and the Stand By light blinks. I can hear the TV turning itself on and off. It is so frustrating.I don't feel comfortable working inside the TV set. How much will it cost me to have someone else fix the short?
  • eric olsen Oct 10, 2008
    When I turn on the tv I don't get a picture and it says a " no signal" . Earlier today it finally came on. But this evening it won't . I smacked the side and it came on for a couple seconds and then went out. The picture in picture has worked thru all of this.
  • 4,234 Answers
The 2 blinks are an indication of an over-current condition, otherwise known as a short. Typically this is because hte horizontal output transistor has failed. If you are comfortable with working inside the set and can solder, you should be able to resolve this yourself. Look for a large transistor (3-legged part) attached to a heatsink close to the flyback transformer (part with large red wire coming out the top). Post the marking on that part here and I'll give you the complete part number. Replace that part and you should be OK. If not, we'll need to investigate a bit more. The part should not be more than about $15.
Keep me posted.
Dan
Posted on Jul 07, 2008
  • Rleo6965 Jan 20, 2011
    Yes it does help. . My Sony KV-XA25N90 have short Horizontal Output Transistor. Already check Diode surrounding the Horizontal Flyback and did'nt find shorted component that will cause the problem. I hope its only the HOT need to be replaced. Thanks. Dan
    Roger
  • goldie615 Sep 11, 2011
    I am not handy like this and I have the same issue. What would this cost to repair at a shop?
    Thanks!
Standby light blinks and tv wont cut on
How many times the standby light at its front panel blinks? Count it. These blinks are fault indications. Check this link for more details about Sony Blinking codes. Count the blinks that occur once, after switch the TV On by its front panel power switch. Check it.
Jan 02, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony trinitron screen goes black and the standby light blinks
How many times the standby light blinks at a time? Number of blinking of standby light with Sony Trinitron CTVs are fault indications. To know more about these blinks, and fault location, get in this site named Electro-help, and pull up older posts there. Try this link, and select the site.
Jul 11, 2012 | Sony Televison & Video
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Apr 22, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My sony trinitron tv wont turn on and standby light keeps blinking
Hi
Blinking of standby light in Sony sets are fault indication. The number of blinks occurs at one instance must be counted. With that bumber I can reach to the fault section inside its circuit; sometimes to the exact fault point too. Just turn OFF the set, and turn it ON, and count the number of blinks at a time [do this atleast 3times and make it sure]; and inform me by Fixya. OK.
Jul 07, 2011 | Televison & Video
I have a Sony 32'' Trinitron that blinks off and on when turned on
I have a Sony Trinitron 32 color tv KV 2168MTJ (quite old - 10 yrs old), and the standby light blinks exactly 200 times (just over 3 mins) before it turns on. Once it is on, it works perfectly. What's wrong with it and how can i fix it?
Feb 07, 2010 | Sony Televison & Video
Sony trinitron not working
The power supply has failed which are very expense and your better off Getting a new T.V.
May 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron
The standby light should be blinking in a pattern. Count,pause,count... Please post the count and that will indicate the circuit in which a problem was detected. That will allow me to give you details and possible solutions.
Thanks,
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA KV-20FS120 20" TV Logo
121 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
