Question about HP PSC 1315 All-In-One InkJet Printer
Vista : what is ICM setting for Photo Printing
HI,
I hv problems printing photos with hp PSC 1315 with 58 no. Cartridge
the photos are having green coulor in addtion to original....they are greenish...
i think there is something to do with ICM Setting...
please tell me which setting would be best...for photo print.....
  • HP Master
  • 691 Answers
Check the HP web page. They have some colour profiles available to download I believe
Posted on Jul 04, 2008
How do i remove the ink cartridge ?
Turn on the unit, then open the print-carriage access door by lifting
the handle until the door locks into place.
The print carriage moves to the center of the unit.
You may want to use a photo print cartridge for
superior print quality when printing photos. With the
color and photo print cartridges installed, you have
a six-ink system. See how to print the best quality
photos on page 22 for more information.
52 maintain your hp psc
hp psc 2200 series
2 After the carriage stops moving, lift the latch to release the print
cartridge, then pull it toward you out of its slot.
3 If you are removing the black print cartridge in order to install the
photo print cartridge, store it in the print cartridge protector.
4 Remove the new print cartridge from its packaging and, being careful
to touch only the black plastic, gently remove the plastic tape.
Caution! Do not touch the copper contacts or ink nozzles.
5 Push the new print cartridge into the appropriate slot until it clicks into
place.
The tri-color print cartridge goes on the left and the black or photo
print cartridge goes on the right.
manual:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01176633/c01176633.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 26, 2010 | HP PSC 2210 All-In-One InkJet Printer
I have an hp photosmart 7960 The problem that I have that I need advice on is that when printing on photo paper the photo comes out green When printing on plain paper the photo comes out O K in its...
You need to set the paper type in the printer settings before printing
start -> control panel -> printers -> right click on your priter and select properties. there you will find the settings, look around there is a page on paper settings.
try changeing those and print again. (select photo paper)
May 01, 2008 | Office Equipment & Supplies
Problems with printing photos. Hp Psc 1410
check the configurations again, if the problem were still there, try with other cartridges.
Aug 13, 2009 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
Photos are not good
Make sure that your quality is set to best and you are using a high quality photo paper for maximum resolution and quality.
Jun 11, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hi I have just inserted a new HP ink cartridge 94 into my HP PSC 2350, as the ink was running low. I was printing photos, which keept printing with a red line throughout the picture. After inserting the...
Try opening the printer properties and cleaning the print heads (should probably be done each time a cartridge is changed), it uses some ink up but should clean the build up from running the previous cartridge dry and hopefully solve your printing problem.
Good luck.
Mar 29, 2008 | Computers & Internet
HP PSC 1350 Photo Printing (Glossy Paper) Pront Quality issue
keep checking the HP site for an updated Driver for your printer, but why not use an online photo printing service like Walgreens or Walmart, You can't possibly print photos at home cheaper than they can, and this way you get actual photographs back.
Dec 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
Too much green
It is unlikely that the sudden appearance of a green hue is due to the printhead or drivers going belly up. If the images on photo paper are OK when using the plain paper setting but have a severe green/blue hue when using the higher photo settings it is likely that the photocyan cartridge has been contaminated with cyan ink. Throw the contaminated PCyan cartridge away and fit a guaranteed photocyan cartridge (OEM or compat). Carry out a deep clean and run several plain papers through on a high photo setting. The green hue will gradually disappear.
Dec 06, 2007 | Canon PIXMA iP8500 InkJet Photo Printer
Printing color
no problem ,the printer settings got corrupted.just uninstall the printer drivers and then reinstall properly.it will be fine. thanks.
Dec 03, 2007 | HP PSC 1600 InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
345 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
