Question about RCA DRC8335
Video tape is stuck in recorder - RCA DRC8335
  • repfamily979 Apr 02, 2009
    I got the tape out of the vcr just fine but now the thing will not take thew tape in try to reset and unplug the unit for 3 hours.?????
    it just makes a clicking noise under the vcr side of the unit??
    any help would be great.
My tape was stuck too. Easy to retrieve, here's how...
Unscrew the five screws. (Two in the front sides, three in the back)
Slide the lid back, then lift it off.
You'll see the "track" where the VHS tapes move forward, then down. Place a finger on each side of the track, and gently glide the tape back up and then forward, manually ejecting the tape.
Slide the lid back on.
***** in the screws.
(Now if only the other issues this device seems to have were that easy!)
Posted on Jan 10, 2009
Check the power supply caps C211-210 near the back beside D201-203 rectifier I replaced 2 220uF at 16v. I used 330 at 35v as I didn't have any higher voltages for a 220uF.
From what I can gather it's probably the power supply and more likely capacitors for most of this units problems
Posted on Dec 20, 2009
Yes, this worked great to get the tape out. The mechanism does not work with pushing a tape in.
Posted on Feb 21, 2009
Toshiba vcr tape stuck after power outage
Do you have any small children who have access to the machine? Kids are notorious for posting coins, half eaten biscuits and bits of toys into the tape slot. 1st give the machine a light shake and see if it rattles, next remove it from any power source and remove the cover. You may find something obvious, if not, reconnect the power, being careful not to touch anything inside, and try to load a tape. Dirty heads WILL playback, but will NOT record. The standard for these machines is load spool to erase head, to video head, to soundhead, then between drive spindle and pinch roller and on to take up spool. Has the tape you are trying to record had the tab removed, if so (like a pre recorded tape) it will NOT record until you place a piece of tape securely over the tab hole.
Jun 21, 2014 | Toshiba Televison & Video
My Panasonic pv-gs180 doesn't record.
If you have Head Cleaning Cassette play it at 10 seconds or use new Cassette for 10 minutes play or record. Otherwise Video Head damage
Mar 10, 2010 | Panasonic PV-GS180 Mini DV Digital...
F 04 - Tape stuck in recorder
F04 means that the mechanism locks during unloading. You need to check the Load motor and it's timing.
You have by the way a K Mech model. This will help you find parts and other information on the mechanism.
Dec 18, 2009 | Televison & Video
I have a panasonic mini dv video recorder. After
close the tape compartment take the batery of press the power button on and holding the power press put the batery back and wait let me know
Jul 07, 2009 | Panasonic PV-GS150 Mini DV Digital...
The tapes In my Panasonic PV-GS14 are stuck and won't run
you cannot move the spindles/cogs in a mini dv tape without pressing down a small lever on the rear of the cassette.
the lever is in the lower right, move the lever, then move the ribbon protector to the open position, then spin the cogs, the tape should be free.
if not, then you have a jamm inside the cassette, you can open these casettes by removing 4 small screws. ( this is a very fiddly job & you may ruin the casette, if you dont know how )
May 09, 2017 | Panasonic Palmcorder PV-GS14 Mini DV...
"menu" button not working-wont record or play back tapes
when the light flashes it means that there is an error definetly.
turn the menu button on off position first and remove the battery.
reinsert battery and turn on recording mode.
Try to remove the tape and reinsert it and see if the operating light is clear.
let me know if the functionality is restored.
Oct 05, 2008 | Panasonic NV-DS65 Mini DV Digital...
Jvc camcorder
Your camera has failure of the CCD image sensor. Please contact JVC Service for free repair, if your camera model falls in their list.
Aug 19, 2008 | JVC GR-D53 Mini DV Digital Camcorder
JVC HR -J655EK Video Stuck
Hi hannah. The simplest way to remove stuck tapes is to remove the top cover. Usually just a couple of screws. Then remove the stuck tape and put the cover back into place. You can also look for emergency eject hole and insert a snall pin into the hole and attempt to eject the disc while repeatedly twisting the pin inside the hole.
May 16, 2008 | JVC HR-J461MS VHS VCR
Wont Record
Usually when a tape starts to play automatically this means that the tab on the back of tape has been removed to stop others recording over it check the tab little black tab in a recess on back edge of tape if this is missing you can put a bit of sellotape over the whole to blank it off this will tell the video tape is ok to record on.
However if the tab is still in place the try putting a small bit of tape over it also to raise the clearence slightly then put back in video and try to record if this still dont work then the mechanism that detects the tab has failed these can be replace but usuall parts are hard to come by now as they no longer make vcrs any more but let me know ok i can assist you further just check tabs in place even try raising it with a bit of card stuck over tab with tape this might make the tab switch work if it has wonr down abit let me know ok.
As you look form back of tape the tab is bottom left hand corner check its flush with the tape if not use sellotape to repair let me know the outcome ok
Feb 15, 2008 | Televison & Video
RCA DRC8335 Logo
408 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
