Panasonic SA-PT1050 Surround sound system. The sub-woofer keeps kicking out on heavy bass music. Have to tap the top of it to get the bass back. Very annoying when watching a concert on dvd.
  • yeww Jan 14, 2009
    I have a 1050 panasonic dvd player with wireless sub.The light stays red and the sub will not kick in.The amp reads w1.Can't find the set up paper to reboot the digital for the sub if this is the problem.Can you help me to get this working,just not the same with no sub.Dwayne Ondik
  • shady1285 Jan 22, 2009
    Can I use this receiver if I don't have a wireless subwoofer?
Error message when i try test center speaker not working
Posted on Dec 05, 2008
I have a MTS surround sound system and when i put the volume up the woofer turns off. whats wrong with it? and how can i fix that
Seems you are over driving the unit and causing it to overheat and the protective circuits are kicking in. U need a more powerful system to play at the volumes you want.
Aug 26, 2017 | Audio Players & Recorders
Htddw7600, brand new, sub amp is not working, only way to get any bass sound is to unplug the sub cable from back of main amp and touch it on side of sub out port.
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Audio Players & Recorders
How do I get my Panasonic sa-pt670 to play all the speaker. watching tv and with ps3
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
Feb 24, 2010 | Panasonic Home Theater System System
Surround sound system is not producing sound through the subwoofe
Several things could cause this, to make sure the sub woofer is working at all disconnect the cable from the back of the receiver. You should hear some sort of output from the subwoofer when you handle the plug. IF so replace the plud and go into your settings menu (press the A and B button at the same time) and go through the speaker set up. It may be that the receiver has not retained the memory that there is a sub woofer connected.
I hope this helps.
Feb 24, 2009 | Panasonic SA-HE90 Receiver
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Sub Woofer
Most likely there is a cold solder connection on one of the circuit boards, or a connector, or any anything else in the audio path.
It is suggested to not use the unit until it is properly serviced. Depending on what is being effected internaly from the cold solder connection it is possible to have some damage.
Jerry G.
Jul 04, 2008 | Panasonic SC-PT1050 System
PANASONIC SC-PT1050 WIRELESS HOME THEATER wireless SUb woofer keeps turning off
http://audio.manualsonline.com/images/but_getmanual.gif.
confirm that you setup subwoofer as indicated in manual above-page11.
Jul 04, 2008 | Panasonic Audio Players & Recorders
The Surround Sound sub-woofer doesn't play bass likes it's supposed to, but the bass plays out of the of the left speaker. What's the problem and how should i solve the problem?
check the setting of your sub and confirm that it is on-check cable of sub and confirm it is connected firmly.-disconnect power cord and reconnect it again.
Jun 26, 2008 | Panasonic Audio Players & Recorders
Subwoofers and amps
If you replace the head unit, that will make a big difference. If not, then it really depends on the type of music you primarily listen to. From a single sub setup, an 8 or 10 in a sealed box is best for punchy base, i.e. alternative, hard rock... A 12, 15, or 18 is designed to reach those lower bass frequencies and are suited better for ported enclosures. I.e. Rap, bass heavy Regge, etc...However, that's not to say that you can't go back and forth between them. The main difference is that a 10 and below tends to be more accurate, and can follow the kick drums, for example, a lot faster than larger woofers. Determine what your primary listening music is, what you want out of your system, and a maximum price for everything first. Then, I can suggest woofers, amps, etc.
Jun 24, 2008 | Car Audio & Video
Subwoofers unresponsive
Check the physical condition of subwoofer to make sure that the surround has not rotted out or been blown away. If ok, then using an ohm meter check for the nominal speaker voice coil resistance to make sure it is within spec. If both of these areas are good then you have destroyed the output stages of the amp(s) driving them. Every 3 db of bass boost doubles the output power. So if you are blasting along at 100 watts and you jack up bass by just 3 db the amp now has to put out 200 at those lower frequencies; go up by just 6 db and you are now talking 400 watts! And what does that do to an amp when you over drive it? You guessed it!
Aug 27, 2017 | JVC MX-G50 CD Shelf System
822 people viewed this question
 Grubhead
Grubhead
