Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
How do I replace the saw on the black and decker navigator handsaw
    Champion:
  • 313 Answers
Manuals are available at www.dewaltservicenet.com looks for
icon find it now.enter the model on the box & search
Posted on Aug 21, 2008
How do I change the blade on the black & decker powered handsaw PHS550 type 2
Go to http://www.manualowl.com/m/Black%20%26%20Decker/PHS550B/Manual/412144?page=2. Follow instructions.
Oct 05, 2014 | Saws
My Black and Decker Drill and Hand Saw have brand new battery pack and brand new charger to BE SURE battery is fully charged but still don't work
it is probably the brushes on the motors are wore out or stuck and not making contact. pretty much junk unless you feel confident enough to attempt repair.
Dec 11, 2013 | Black & Decker Black and Decker 18V...
How to put the blade into the black and decker 3.4 amp powered handsaw
#1) You have to locate the blade release button on the saw (see your manual). The opposite side of the release button is a screw-like OVAL shaped PIN. To insert the blade, the direction( or position) of this OVAL shaped PIN has to match the OVAL shaped hole in the blade. You could use a screw driver to change the direction/position of this OVAL shaped pin. You have to push down the release button when you use the screw driver to turn.
#2) Hold the blade in Vertical position in your right hand. The "Oval" hole is on top. The teeth is facing your left hand. You will see that the "oval" hole on the top of the blade is a "horizontal" oval.
#3) Hold the saw (handle) in your left hand as if you were going to saw using your left hand.
Now peek through the hole of the saw and find the direction of the OVAL PIN. It has to be a "horizontal" (or lied down) OVAL. If it is not, use the screw driver to adjust it.
#4) Hold the blade using your right hand. Oval hole on top, teeth facing your left hand. Insert
the blade from the bottom of the saw. What you needed to do is to insert the PIN into the hole
of the blade. When you inserted the pin into the hole of the blade, slowly turned the blade upward, the blade will lock by itself.
Oct 15, 2013 | Black & Decker PHS550B Powered Handsaw...
Looking for replacement blades for Black & Decker Zip Saw
Its on ebay http://www.ebay.com/itm/NEW-BLACK-DECKER-ZIP-SAW-11-PIECE-CUTTING-SET-74-691-/260888941452
only 15.00
Apr 02, 2012 | Saws
We can't get the blade to go in
There should be a button on the right side of the saw to press in to open the clamp for the blade.
Blade changes require no tools. There will be a pin that engages the hole in the blades.
May 09, 2010 | Black & Decker PHS550B Powered Handsaw...
How do I remove the blade and reinstall a new blade in my Navigator saw. Thanks.
Before you can mount a new blade onto your black and decker navigator you must make sure the holding pin, (the flat side of the oval part) is paralell to the bottom of the saw. If it is not push the black button that pushes the pin out as hard as you can and with a small wrench move it into the proper position. Mount you blade @ 90 degrees and push it up into position
Oct 01, 2009 | Black & Decker 11-3/4" Navigator General...
Plastic safety key broke Black & Decker table saw cat# 1736
Try sears .They shoul be able to get it eor you
Mar 14, 2009 | Black & Decker Saws
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
65 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
