Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
I own a cuisinart coffee maker and it leaks from the bottom. I've seen a number of posts on this subject, but no replies or any info on how to fix it. It seems to be a safety issue since it's leaking around the power cord. Any suggestions on fixing it?
  • 3 more comments
  • jkiyono Aug 05, 2008
    We've had our Grind and Brew for about 3 years and it too has begun to leak from the bottom. We've cleaned it, replaced the filter and even decalcified it per the instructions in the manual all to no avail. We also called the customer service number to see if others had reported the same issue and they told us no. We're still looking for a solution.
  • Anonymous Sep 06, 2008
    My Grind and Brew is overflowing the coffee and grounds on the cabinet and under the pot. I have decalcified, changed filters, and I do not add "too many beans" ...any ideas??
  • Anonymous Sep 15, 2008
    I have had the maker less than three months and have had it leak all over the counter on several occasions. This with ground coffee and making less than 10 cups. I have also entered the kitchen to see that the door has sprung open leaving another mess. I am very disappointed with this coffee maker. I will not buy any Cuisinart products in the future.
  • lrosenwasser Dec 02, 2008
    Mine is leaking from the bottom and also doing absolutely nothing - no beep, no grind, no brew...Thoughts?
  • ishaw Dec 15, 2008
    Only had ours a few months and it leaks aprox. every 10 pots. I clean every part very well. The only thing I might be doing wrong is adding too many beans. I will be trying this tomorrow (today it overflowed...that is why I am searching!) with less beans.
  • 515 Answers
I think it´s the tube from the water tank to the boiler that is leaking.
Posted on Jul 14, 2008
I have a cup o matic and it has recently started leaking from the main unit...???? Can I fix it?
you can if you can find where the leak is, and as long as it is just a worn o-ring and not a crack. You could contact Cuisinart for service? There are some articles on your particular problem in the main link at the bottom.
Pt 1: How To Use: Cuisinart SS-1 Cup-O-Matic Coffee Maker - YouTube
? 10:04
https://www.youtube.com/watch?v=jEPf5hXWkB4
Oct 18, 2007 - Uploaded by Jay Brewer
Learn how to use coffee pods and ground coffee with the Cuisinart SS-1 Cup-O-Matic Coffee Maker.
SS-1 - Coffee Makers - Discontinued - Cuisinart.com
https://www.cuisinart.com/discontinued/coffee_makers/ss-1/ Regular or bold, large or small - your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffeemaker, it's easy to brew your cup ...
[PDF]Cup-O-Matic™ Coffeemaker SS-1 - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/ss-1.pdf Cup-O-Matic™ Coffeemaker. SS-1. For your safety and continued enjoyment of this product, always read the instruction book carefully before using.
Amazon.com: Customer reviews: Cuisinart SS-1 Cup-O-Matic Single ...
https://www.amazon.com/Cuisinart-SS-1-Matic-Coffeemaker.../B000RIAIXO Find helpful customer reviews and review ratings for Cuisinart SS-1 Cup-O-Matic Single Serve Coffeemaker, Black and Brushed Chrome at Amazon.com.
Cuisinart® Cup-O-Matic™ Single Serve Coffee Maker - Bed Bath ...
www.bedbathandbeyond.ca/store/product/cuisinart-reg-cup-o-matic.../1014760199 Regular or bold, large or small, your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffee Maker, it's easy to brew your cup ...
Cuisinart Cup-O-Matic Single Serve Coffeemaker Review
www.goodhousekeeping.com/.../cuisinart-cup-o-matic-single-serve-coffeemaker-881/ Rating: 2 - ‎1 review
Unlike coffeemakers that only make a cup at a time, this model can be used with your favorite ground coffee as well as from coffee pods.
Single Serve Coffee Forums
cup matic leaking water Google Search
Sep 03, 2017 | Coffee Makers & Espresso Machines
My coffee maker is leaking from the reserve. Is there a fix? I don't see a crack. It just started recently.
Reserves usually has a overflow hole on back . If not you might look for leaks around bottom were reserve meets up with coffee maker. Maybe leaking there.
Oct 29, 2015 | Cuisinart DCC Coffee Makers & Espresso...
How to fix the leak from the bottom of my cuisinart dgb-900bc
Re: Cuisinart grind and brew model DGB900BC leaking from the bottom. Finally fixed it before buying a new one. Remove the 4 torq screws (#10 bit check auto stores) from the bottom and remove the bottom. You will see a horse shoe shaped metal coil that heats the water from the resevoir. I found that the coil had a small hole in it. Cleaned it well and applied a coat of epoxy paste to the leaking area ( I used a product called PC11 from Ace) So far, no leaks, and the coffee maker is working like new.
Aug 10, 2012 | Cuisinart Dgb-900BC Grind & Brew Thermal...
Leaking underneath
You are not alone having the water leak in your SS-700. For better understanding what caused that leak please read the review on Cuisinart SS-700:
http://www.cuisinartfoodprocessordeals.com/cuisinart-ss-700/
Nov 22, 2011 | Cuisinart SS-700 5-Cup Coffee Maker
Water is leaking out the bottom
You MUST return this product or throw it away! This is a problem seen often and the biggest risk is electricution. The hold tank for the fresh water is leaking and it is leaking water into the area housing the heating element for the caraf as well as the pump and a few other nasties.
This is a very serious problem. Do not try to fix it. A new unit is much better than either getting shocked or burning your place down.
Dec 04, 2009 | Cuisinart DCC-1200 Coffee Maker
Leaks water from the bottom
Under warranty. Cuisinart will resolve. Thank you.
Dec 08, 2008 | Cuisinart DCC-2200 14-Cup Coffee Maker
Bunn 10 cup maker
the exact same thing happened to ours. i went to the bunn website under support, and emailed them the exact same question you have here. i got a reply asking for our serial number from the bottom of the machine. as soon as i e-mailed that info to them, they told me that it was less than three years old (i guess they can tell from the serial number), still under warranty, gave me an RGA # and instructions to mail it back in for repairs. i'm getting ready to pack it up now.
Oct 24, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Water leaking from bottom of coffee maker
The water hose on the bottom of the coffee maker is worn, due to the heat. It needs to be replaced. this is the second time for mine.
Mar 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Bottom screws
I was just trying to figure this out. I think it's a molded piece because I tried a small hex tool, and everything else. Nothing seems to work...
I HATE trashinh this thing! BOOOOO Cuisinart!!!!!
Mar 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Contact Cuisinart warranty regarding your problems 1-800-726-0190
I don't know if < coffeediva22 > is still around, but I found this post on SAT 3/28/09 @ ~ 0900 in STL, MO---VERY HELPFUL---called cust serv @ indicated 800# and was told $10 each way deal still good -BUT- rep said:
"did you try re-plugging back into outlet after 1 hour"??? -and- " 1 hour is our 're-set' time for this model".
While I was on the line, wife plugged back in an VOILA !!!! IT WORKS !!!!
no $20; no TORX #10 security screwdriver to get bottom off;no NOTHING!!!
just do the HARDEST thing when you go to kitchen, NEEDING coffee and get NADA-----WAIT AN HOUR!!!!!
the nutty professor
Jan 14, 2008 | Cuisinart DCC-2000
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
204 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
