Audio problem with my home L.G theatre
The amplifier of my home theatre displays error message"mic-out, mic-in" intermittently and cuts the sound repeatedly.
  • 682 Answers
Please bring lubricat contact cleaner and apply the spray in the socket where you put your mic and insert mic jack in and out many times.
Posted on Jul 08, 2008
How much do they cost. I am going buy one.
Amanda, Audio & Video Receivers prices can range from a couple hundred dollars to thousands. Decide on your needs and then search the stores/ net. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Receivers Audio Home Theatre Receivers Best Buy Canada
Home Theatre Receivers Receivers and Amplifiers at 2001 Audio Video
Amazon com Receivers Amplifiers Electronics Amplifiers Receivers...
How to buy receiver The ultimate buying guide
Aug 26, 2016 | Audio Players & Recorders
I am having 21 inch onida black 200 tv .I have recently bought philips home theatre. please let me know how to turn off internal speakers of onida tv and how to turn on external speakers to send audio...
By the looks of it, the only output you can use from the tv will be using the 2.5mm jack plug headphone socket, get a cable to convert this into twin phone (red/white) for stereo sound to your amplifier. (they are very cheap £2 or so) The Home theatre system should be able to give you a psuedo surround but you wont get full surround.
May 02, 2011 | Audio Players & Recorders
Purchased LG's LHB335 home theatre 5 days ago to enhance my LG 42LBX TV. Problem with home theatre sound as the audio cuts out for a couple of minutes every 15-20 minute intervals. Problem is intermittant...
i bought mine in january 2011 and just started having the same problem. i have to turn the head unit off and back on again to get sound back. any fixes for this yet?
Dec 06, 2010 | LG LHB335 Theater System
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
I have a panasonic HT-740 home theatre system as soon as you turn it on it makes a pretty loud humming sound then "F61' pops up them immediatley shuts off
Possible that you have an error amplifier safe cut off of the power after analysis of the current status. You could probably have a power amplifier failure maybe in the output. It is important to have some good knowledge of the internal circuit before anything could be traced tot he safe errror cut off. Hope you find a good help/ panasonic service centre for a quote. Good day
Jun 27, 2010 | Televison & Video
My panasonic sa-vk90d is displaying an f61 error
That code means the audio amplifier IC are damaged and need to be replaced
Jul 13, 2009 | Audio Players & Recorders
Connecting an audio/video transmitter to Yamaha HTR 5830 Amp
If you want to get sound out to speakers use the KEFF WIRELESS SYSTEM as this will not break up or cut out.
Hope this helps.
CABLE GUY.
Dec 29, 2008 | Audio Players & Recorders
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Nov 24, 2008 | Audio Players & Recorders
Panasonic SC-PT850w sound cuts out
Are you watching 10HD off the air from an antenna? You are losing video and audio intermittently, which may just be indicative of a weak signal. Does your TV have a signal meter?
Apr 27, 2008 | Panasonic Home Theater System System
F61 error message
NEED TO CHECK YOUR FANS AND THEN UR AUDIO STAGE.
Mar 27, 2008 | Audio Players & Recorders
231 people viewed this question
 Grubhead
Grubhead
