Question about Konica Minolta magicolor 2300DL Laser Printer
2300dl toner problems
I recently installed, some toners for my 2300dl, they were not new toners, but partially full toners, high capacity, i can't get my unit to "see"the new amounts installed in the unit, for the black toner, or the opc drum. I went into the service menu, i reset factory defaults(mistake) now it shows everything as having 100% life left, and i cant get the black toner to show as high capacity.
  • c00ljim Jul 04, 2008
    i had also installed a partial cyan, because the unit was telling me it needed to be replaced, i put a partial on in that slot, selected the toner size, and it came up as having 58% life, so im not fully understanding here.
  • 788 Answers
Unfortunalely printers and there drivers estimate toner life buy counting the amount of dots draws on the pages. Say a cartridge is rated for 3000000 dots when new, the printer will know after printing 1500000 dots that the cartridge is about half full. If you replace a cartridge the printer will assume it's new as the ID tag will be different from the last cartridge. There really isn't any way of modifying or specifying the age of a cartridge. You will just have to keep using it until you start seeing drop outs on the page, then you will know it is almost empty. Shaking it a few times will usualy help stretch the life of a cartridge.
Posted on Jul 04, 2008
  • Dean Joly
    Dean Joly Jul 04, 2008
    Ok, maybe your printer writes it's current dot count to the chip in the cartridge. This it would seem as though your printer cannot read the chip in your problematic cartridge. Check the contacts on the cartridge and the matching contacts inside the printer for wear, deformation.
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
My magicolor 2300dl printer is showing waster toner box full and won't print but the waste toner box is empty and new. Is there a reset button on the printer to bypass this error?
1. Empty the waste box.
2. Read p66 of
3. Identify the "Waste Toner Full Detecting Sensor" which tries to pass a light beam through the protruding plastic slot on the waste box that engages with the photocell.
4. Use a dry cloth to clean dust off the photocell transmitter and receiver and also off the protruding plastic slot, so that light will now pass through.
5. Refit the waste box and enjoy the $$ saving.
Sep 23, 2009 | Konica Minolta magicolor 2300DL Laser...
My prints are coming out very faded. There is a new drum unit installed and all toner cartidges have toner. The black is down to about 22%. What is the problem?
Open the side door and remove the toner bottle. You will then find a small blue item which will slide out. Clean the dust off the central clear area and this should improve print quality.
Aug 13, 2009 | Konica Minolta magicolor 2300DL Laser...
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Wast toner full
You need to replace the waste toner kit part number 1710522-001
Jun 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Toner Capacity
This does not need to be done. there is a chip/fuse built into the toner that basically tells the printer how many paes that toner has printed in its life time. no adjustment is needed it is all automatic
May 31, 2008 | Epson AcuLaser C900 Printer
Minolta 2300DL ghosting
I just had the same problem with my 5430DL. It was a bad toner cartridge. The bad cartridge is at 73% full, and had not been a problem until recently. I had been troubleshooting and finally remembered that I had the old cartridge with toner still left. I swapped them out and no more ghosts. Swapped back and the ghosts came back. I have ordered another new toner cartridge and fully expect the problem to be resolved.
Jan 28, 2008 | Konica Minolta magicolor 2300DL Laser...
Quit Printing & Loud annoying sound
The sound is coming from the new toner cartridges. The roller is sticking and causing the gears to make that noise. I removed the toner cartridge and manually turned the roller until it turned smoothly. (this a little hard but it worked). no more noise!
Dec 09, 2007 | Konica Minolta magicolor 2300DL Laser...
Toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
160 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
