Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag gemeni oven
When we turn on the oven and set for 350...it taek a full half hour to get to 170 and then stops
  • 37 Answers
This sounds like a faulty igniter in the oven (about $45,00) online and you can replace it yourself. Look inside the oven and remove the bottom. You will see a long tube where the gas comes out. At one end of the tube is a coil of wire that is suppose to get white hot and yours is bad, probably only turning red when you turn on the oven. Good luck.
NSSMS
Posted on Jul 21, 2008
Gas owen overcooks
I get this service call a lot so lets verify temp before we discuss possible causes set the rack in the middle of the oven hang an oven thermometer in the center of rack set a 350 let run 1 hour check the temp after an hour this gives the oven enough time to cycle and stabilize this will give you the true average of oven, temp placement of thermometer is important plus or minus 15F on either side of 350 is not that much of a big deal the max range for a temperature offset is usually 30F, there should be a tech sheet in a plastic pouch on the back of the unit now if you do find it to be running 50F too hot well there are test to determine if the temperature sensor is operating correctly it should read appx. 1654 ohms at 350 this tells the control board to open the heat relay stopping power to the gas valve lot of work you have to have the oven out back panel off to access the wiring going to control unplug machine at 350 disconnect wiring from board to ohm out sensor, sensors go bad and so do boards, sensor is cheaper try changing it first.
Apr 04, 2015 | Maytag Kitchen Ranges
Maytag Gemeni double oven stovetop stopped working
Thats the controller, you'd need to call a professional no quick fix for that one sorry. besides attempting to fix it your self will cause more damage than good
Jan 02, 2008 | Maytag MER6772 Gemini Electric Kitchen...
This touch 850 series double oven is only heating up to 170 when dial is on 350 do I have a bad element?
Elements usually either work or they don't, if it comes on the but does not give enough heat the thermostat is bad. If it was cleaned inside recently, check the routing of the stat lead perhaps its kinked etc.
Mar 16, 2015 | Maytag Ovens
Oven door is locked somehow
UNplug it and let it sit for a half hour to a hour then plug it back in and it might reset itself.
Jan 05, 2013 | Maytag Stove / Oven / Range Cooktop -...
The oven will not heat up over 170 degrees (after a half hour) and I hear a lot of clicking in the control panel
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jun 17, 2011 | Maytag 30" Self-Cleaning Freestanding...
We had a power outage and now our Maytage Gemeni stove won't go back on. Can't test the outlet, of course, since it's that weird huge plug, but all the other electricity is fine. The oven is completely...
Hi!!
Check breaker box for a tripped Double Breaker, probably 30A, If breakers are OK, unplug unit from wall outlet and wait 15 min. to reset the control board, plug unit it back up and check Range. You can check for power at the outlet using a voltmeter set on the AC mode.
Keep me posted!!
Dec 04, 2010 | Maytag MER5550 Electric Kitchen Range
Oven temp maytag MER5770
check your element if thats fine u need to replace your erc and possibnly your oven sensor
Mar 19, 2009 | Maytag MER5770 Electric Kitchen Range
Oven will not stay on
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Jul 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oben takes half an hour to heat up
I doubt its the igniter. It could be a faulty gas valve or maybe the orifice is blocked, and not letting enough gas into the burner
Jan 28, 2008 | Maytag PGR5710 Performa Gas Kitchen Range
Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Nov 20, 2007 | Maytag MER5775Q Electric Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
79 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
