Question about RCA RP5420 Clock Radio
RCA RP5420B 2Band AM/FM Clock Radio
Electric went off and now when service is back on the Auto Time Set displays the wrong time. Even though batteries were in at the time the screen went blank; batteries were new. How do I set the correct time ?
There is no sliding bar on the right rear and I don't want to throw out a brand new clock. PLEASE HELP.
  • 1 more comment
  • Anonymous Aug 18, 2008
    My clock is displaying the time approx 15-20 min ahead of what it actually is. I was wondering if the atomic clock was off?!
  • Plaird Sep 01, 2008
    This clock is the most user unfriendly clock that I have ever had!! I can't set the time. I thought it was a sefl setting clock. I can't set the alarm. I have only had this clock a few weeks and don't want to through a new clock away and get another one. I layed it on its back, put the three buttons in place and plugged it back in, still flashes. How do you set the time, when you can't even keep it in the right time. RCA modle RP5420B
  • Anonymous Apr 24, 2009
    A very difficult clock radio! Brand new and so frustrated with it that I AM throwing it out! Same problems as the others.... can't set time, can't set alarm and when you set the alarm, it changes the clock to that time as well. Very unhappy with this product!!!
At the top of the clock, there is four positions for the slider. The first is shown as a key, which I assume is the automatic time setting mode. The second is Wake 1, the third is Wake 2 and all the way to the right is a manual time setting mode. If you slide it all the way to the right, you can set the time, then either keep it in that mode or return it back to automatic mode. Either way, you now have the correct time displayed.
Posted on Jan 12, 2010
  • twaltner Nov 28, 2010
    This tip worked perfectly - THANKS!
    The setting to the left which has the picture of a key, is nothing more than a place to LOCK the slide switch so that you don't accidentally change the clock, the wake-1 time or the wake-2 time.
The set time function may be set by setting all three alarm settings to the current time Then slide the alarm function off and the current time will be displayed on the clock.
My opinion; Thompson Inc. should be banned from selling anything!
Burned twice, smarter now.
Posted on Mar 10, 2009
Addendum to previous post on Sept 10 by me..
The slide switch in the lower back middle should be all the way to the right before unplugging the power.
Sorry that I missed that. Rattler
Posted on Sep 10, 2008
How do I set the time on a RCA USB Charging Clock Radio RC142?
Setting clock manually
1. Press and hold Set Time to enter the clock setting mode.
2. Press HOUR+ and MINUTE+ to adjust the time.
• Press and hold to adjust the time value quickly.
• The digits on the display ? ash in clock setting mode.
• The clock is in 12 hour format. The AM or PM indicator will illuminate to indicate the current time setting.
3. Press Set Time again to save the time setting
RCA RC142 User Manual General Controls
Mar 18, 2016 | RCA RC142 AM/FM USB Charging Clock Radio
Why does my nelsonic nlc690 am/fm alarm clock radio display 18:88 and not allow me to set the time?
Sounds like it is broken!
Unplug it and remove the backup battery if it has one. Count to 10 and put the battery back in and plug back in.
If that doesn't work, just buy another one as they are cheap enough!
Nelsonic Led AM FM alarm clock radio NLC690 AWESOME CONDITION
Jan 13, 2016 | Audio Players & Recorders
I need a manual on how to set the time and alarms on fm/am cd clock radio model # rp 5600a
To set the time, press Set (furthest left button in the line including the Snooze) repeatedly until the clock icon shows on the display. Then press the FWD or REV buttons (on either side of the Snooze button) until you reach the current time. Press and hold to advance the time more rapidly. Press Set to save the time.
To set the alarm, press Set until Wake 1 or Wake 2 is shown on the display. Then follow the same directions as changing the time. Press WK1 or WK2 on the front of the clock to select the type of alarm.
The manual for the RCA RP5600 is available on the product page: http://www.rcaaudiovideo.com/audio/clockradios/?sku=RP5600 . See the Support/Manuals tab. The direct link to the manual is http://audiovox2.info/docs/common/RP5600/RP5600_OM.pdf .
I hope this helps.
Oct 22, 2011 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Sangean h2o1 clock is flashing. The radio display doesn't flash - only the clock. I've reset the clock, changed the batteries, and generally played with the other settings. Can't figure out why the time...
Here's the thing: When you change the batteries, the radio thinks you need to reset the time, even though the time has been preserved and is correct even after you change the batteries. Here's what you do: Pretend you need to reset the time. With the radio off (recommended), press and hold the "Band" button with the "set" notation underneath it. The hour will flash. "Reset" the hour by using the tuning buttons, as you would if the radio were new, and then change it back to the correct hour. Press the "Band" button again and repeat the process for the flashing minute display. Press "Band" again to end the process. You will have successfully fooled the H201 into thinking that you have reset the time, and the time display will have stopped flashing. (This does not appear to work if you do not actually pretend to change the hour and minute and just keep pressing the "Band" button -- you have to go through the procedure as though you were actually changing the time.)
Aug 31, 2010 | Sangean H201 AM/FM Radio
How do you set the time and alarm on the RP5600A
Setting Clock
1. Press SET repeatedly until a clock icon
2. Press REV or FWD to set the clock
time. The time decrements or
increments will follow by a faster rate
when you press and hold the buttons.
AM or PM icon will also show beside
the time.
3. Press SET when finished.
Setting Wake Time
This unit allows two wake times to be set.
1. Press SET repeatedly on the top of the
unit until you see WAKE 1 or WAKE 2
flashes on the display.
2. Press REV or FWD to set the respective
wake time. The time decrements or
3. Press SET repeatedly until you see no
WAKE 1, WAKE 2 or icon the
display.
Selecting Wake Source
You may be woken up by radio, CD or alarm.
1. If your desired wake source is radio or
CD:
• Wake by radio - select an AM or FM
station (see directions on “Radio”).
• Wake by CD - insert a CD in the CD
compartment. If you want to be
woken up by a specific track on the
CD, press and hold wake up - cd
track
on the top of the unit and at the
same time press REV or FWD to select
a desired track.
2. Set a wake time (see above direction).
3. Press WK-1 or WK-2 repeatedly at the
front of the unit to select a waking
mode. Corresponding icon lights on
the front of the unit.
- Wake 1 by alarm
- Wake 1 by radio
- Wake 1 by CD
In case of Wake 2, “2” shows at the
centre of the icons.
Sep 30, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
RCA Clock radio RP5420B time setting
Move alarm switch to the far right, then plug in. You will notice a clock icon to the far right.
Sep 11, 2008 | RCA RP5420 Clock Radio
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
RCA RP5420 clock radio will not auto set time. Please help
Bob, My auto-set worked fine. I'd suggest setting the time manually (by sliding the top-rear slider all the way to the right and using the '<<rev' and 'fwd>>' buttons) if you are still having problems.
Nov 11, 2007 | RCA RP5420 Clock Radio
Radio FQ display
I just bought this too, and mine does the same. I think it's defective. Back it goes...
Jan 15, 2007 | RCA AM/FM Clock Radio (RP5412)
RCA RP5420 Clock Radio Logo
3,031 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
