Question about Dayton Electric Heater
Dayton G73 wire hook up with 10/3 NM-B wire
I'm trying to hook up my new Dayton G73 heater and I have a spool of 10/3 NM-B wire that I used for my dryer. The schematic shows the black, white and ground hook up. What should I do with the red wire from the 10/3?
  • 108 Answers
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Posted on Oct 23, 2008
  • greg
    greg Oct 30, 2013
    Hire an electrician - your home insurance will not be honored if your home burns down because you got wiring info from an anonymouse idiot on the web... The G73 is NOT a 3 phase heater, it needs two phase from a 240v panel. You should use 10/2, with Black and Red as hot, copper ground to green ground at the heater.
I have installed a Dayton G73 heater in my garage along with a 240V outlet. I am using a 3 prong dryer cord and I am having difficulty figuring out which wire to hook to L1 and L2. I have determined the...
here's a link to the install guide
www.air-n-water.com/manuals/G73.pdf
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/Installation-Dayton-G73-Garage.htm
Nov 02, 2009 | Heating & Cooling
Where do i connect load wires to 240 volt baseboard heater
240 load goes to 240 supply if on all the time
or 240 load goes to one leg of switch other leg goes to supply
Oct 27, 2009 | Dayton G73 Utility Heater
Wiring
Since it is a 30 amp heater you need to run #10 gauge wire and use a 2 pole 30 amp breaker, since it is 208/240 volts. I hope this helped you.
Jan 14, 2009 | Dayton G73 Utility Heater
Hooking up my heater
The white is the common neutral, it is probably a 3 wire unit, and you are missing the ground wire. Check inside the control panel and see if someone wired it using the white wire for the ground, it will be screwed into a terminal lug. Check the schematics to see if the unit requires a common neutral to run the controls.
Nov 24, 2008 | Dayton G73 Utility Heater
Dayton G73 heater
should be adle to if the voltage is right
Nov 09, 2008 | Dayton G73 Utility Heater
Installing a Dayton G73
How many amps is your service? And what gauge wire did you use for the heater?
If your service is only 40amps that is your problem. You don't have enough amps for the heater and the rest of your house, you will have to upgrade your service.
Nov 02, 2008 | Dayton G73 Utility Heater
Dayton G73 electric heater
I just got my G73.  It comes with a new note that says "below 50 degrees the fan will cycle randomly (and might seem like its not working correctly) but once it is above 50 it will cycle normally."  it uses that to let the element re-heat quickly to bring the room up to temp faster.
Feb 13, 2008 | Dayton G73 Utility Heater
If that is a 240V unit then you are correct wiring L1 and L2 to black and red. Unless the unit uses 120V for something like a control panel, it doesn't need the neutral.
Jan 14, 2008 | Dayton G73 Utility Heater
Dayton Electric Heater Logo
605 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
