Question about Janome Memory Craft 9000 Computerized Sewing Machine
Windows Vista & Window XP operating system
Is it possible to have both of the subject operating systems loaded in a PC. So that I can use the XP for daily use; when I have the time, I could test using the Vista until I am familiar with it and then use it at a later date. Until Vista is running smoothly and maintain error free constently, due to the fact that Microsoft do not support XP soon. If the two operating system consist in one PC, would it slow down the speed?
Pl advise.
Thanks,
BL
  • 51 Answers
No sorry it's not. Best bet...get windows Service pack 3, it's a substitute for Vista since it was a fail from the start.
Posted on Mar 30, 2009
  • Serial Killer
    Serial Killer Mar 30, 2009
    Even if you do create another partition, won't that mean that you won't be able to choose which partition to boot up from? It is one disk even if you have four partitions. Just commenting, was bit unsure
  • Serial Killer
    but it might be possible if you have two hard drives where you can choose which one to boot from at your p.o.s.t (primary operating system table)
  • 127 Answers
U can dual boot them u need 2 creat another paertision enough 4 the other os
Posted on Mar 16, 2009
I recently bought a new computer ans tryed load my software to my emtions embrodiery machine and it will not load
It is likely the software you have is not supported by the computers operating system, this is true of MS Windows 7 and up operating systems. You likely have software for the older XP system.
Oct 06, 2016 | Sewing Machines
Loaded 3D Embroidery software on computer but will not recognize the dongle plugged in to the usb port. Drivers for dongle did not automatically load, went online to find a HASP file (driver I think) and...
1st try another usb port
2nd uninstall the software and plug the device in only after you have reinstalled the software and you are asked to plug it in. If it doesn't ask then install the software first and try again.
You can also right click on my computer and select manage.
then on the left side of the window select device manager, unplug and plug back the usb dongle and see if any devices appear or disappear also note any yellow ! marks. you may have to press the scan for new hardware button or right click on the window to scan for hardware changes.
Jun 18, 2008 | Husqvarna Rose
Got a newer laptop running on windows 7 ultimate. Software on futura ce 200 doesn't want to finish loading
YOUR PC RUNS WINDOWS 7 PRO OR ABOVE If you have Windows 7 Professional or Above, the solution torunning any XP software is fairly easy. Go to http://www.microsoft.com/windows/virtual-pc/download.aspx.Select your Windows 7 system and language, follow ALL the instructions, andMicrosoft will take you through to running XP mode on your Windows 7 system!Hurray! If you still have a problem with the USB cable being recognized, besure you're plugging it into the BACK of your machine, not through a hub or inone of the front ports. The program for the embroidery machine and the USBcable require more power than either of these allow, a technical point Singerdoesn't seem to be aware of. You should be fine to install the machine'ssoftware and run it from within the XP mode now. YOUR PC RUNS WINDOWS 7 HOME, STARTER OR VISTA Unfortunately, you'll need to have an original of Windows XPfor this, no way getting around it. Hopefully, you still have a copy of itlying around, or have a family member, neighbor or friend who does. Maybe acheap eBay buy? Doesn't matter if it's XP Pro or Home. This solution is quite abit more complicated, but you can get there. I run Windows 7 Home and I usethis solution to successfully run the embroidery software on my Singer FuturaCE-100; the application should be no different for any other machine requiringXP software and unable to run in either Vista or Windows 7, so take courage andcharge forward! You're going to want to download a free and SAFE softwarecalled VmWare Player. The download requires you to register, but there's nocost, it's updated regularly to keep it safe and has been thoroughly checkedout by a lot of geek experts out there. It's available at http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0.Fill in the required information, follow the instructions from the email you'resent, and download the software. Normally, the software will be downloaded tothe "Downloads" folder, unless you tell it to download elsewhere. Before you do anything else, place the Windows XP CD in yourCD drive. Make sure you have the registration number ready. Now go to the"Downloads" folder, double click on the VmWare installation file(Vmware-player-etc, etc) and follow the instructions to install. Once that isinstalled and you've rebooted your PC, double-click the icon on your desktopfor the VmWare Player. It will automatically open up with a Welcome screen.Click on "Create a New Virtual Machine." The next window will automaticallyshow under installer disc "Windows XP (Pro or Home" detected." Just click next.Enter the XP product key and keep entering any required information in theBLANK spots in the following screens. ANY spot filled in LEAVE ALONE. Now leave the PC alone-the process will take about 20minutes. Once it is done, VmWare Playerwill automatically launch the Tools Installer to integrate the virtual XP withyour computer. It may have to download or update the tools, so if you see ayellow banner at the bottom of your window, simply click Update Tools orInstall Tools depending on your situation. The tools will automaticallydownload and install, though you may have to approve a prompt or two. You will be able to click between folders on your Windows7/Vista system and the XP Virtual Machine to copy and paste your designs backand forth. I strongly suggest that whatever AntiVirus software you use on yourWindows 7/Vista you also install on the XP, as it will look for updates on theinternet and will thus be subject to any viruses out there. Make sure you useany firewall, as well, if you use something other than the XP default (you'llknow if you do). Now-close the VmPlayer completely. Don't restart it, closeit. Then reopen it. Do you get a message at the bottom telling you that the USBdevice connections are disabled? We have one more step, then, before installingthe embroidery machine's software. USB DEVICE CONNECTIONS DISABLED OR USB ARBITATION SERVICEFAILS/TERMINATED OR DEVICE ATTACHED TO THE SYSTEM IS NOT FUNCTIONING. Arggggh! One more thing? Okay, this is the really technicalpart. The problem is you have an AMD processor, not an Intel, in your machine.Congratulations on a smart purchase. VmPlayer has a little conflict with it.What I'm going to have you do may seem a little scary, but it is simple todo-and there is a backup so that if anything goes wrong we can fix it. JUSTDOUBLE CHECK EVERYTHING YOU DO BEFORE YOU DO IT. Okay. Your going to go into an area that's supposedly forbidden inyour computer-nonsense. Make a backup, be careful, and understand that otherswho know what they're doing have written, gone over, and done theseinstructions before you. And my PC works just fine WEEKS after I've done this! First, let's make a back up. Click onto the Start icon in thelower left hand side. See that blank line on the bottom just begging for somethingto be typed into it? Type "regedit" and hit ENTER. Click on FILE, EXPORT.Select DESKTOP on the right, name the file REG BACKUP and click SAVE. Now youhave made a full backup of your registry so if anything goes wrong you can goright back into "regedit" and go to FILE, IMPORT and select the file. See?Easy. Now. In the Registry Editor screen that you've opened, 1. ClickHKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Class\(36FC9E60-C465-11CF-8065-444553540000). 2. In the right hand panel, if UpperFilters exists, delete it. YES, delete it. 3. Go toHKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\. 4. Delete the usbfilter string. 5. Close the registry 6. You will want to go into Start, then Computer.Double Click on C, then Windows\System 32/Drivers. Scroll down to the fileusbfilter.sys and delete it. Now reboot your computer. FINALLY-REINSTALL YOUR EMBROIDERY SOFTWARE ACCORDING TO THEORIGINAL INSTRUCTIONS FROM YOUR MANUFACTURER. And yell at them for not paying for the original programmerof the software to update the software properly to operate on Vista and Windows7! I hope this helps everyone! It took a bit of research, butit's been well worth it. Happy embroidery!
Mar 22, 2011 | Singer CE-200 Quantum Futura Computerized...
I have a furtura ce-100 version 1.0.02 trying to down load disc to my HP note book w/windows 7
Mar 14, 2011 | Singer CE-100 Futura Computerized Sewing...
My software will not load on the windows 7. I have the upgrade, autopunch, downloaded the patch but nothing is loading. It was running on my old computer butnot on the windows 7.
Dec 28, 2010 | Singer CE-200 Quantum Futura Computerized...
I just installed Singer Futura CE 100 software to my laptop with Windows 7 operating system. I also installed Futura Service update 1.0.0.2. Now when I try to open the Futura software, I get this error...
Dec 28, 2010 | Singer CE-100 Futura Computerized Sewing...
I need a new computer and am wondering if windows 7 will run the old creative software for my 7570? i do know it would not work with vista thank you
If it didn't fly on vista, it will likely not work on 7 either. Fret not, as you can still buy new machines with XP loaded on them. It is a nice, stable operating system that is still sought out by businesses, etc. I would look on newegg.com or tigerdirect.com.
You can also downgrade a windows 7 to XP. If your program didn't run on XP, then you are stuck.
farmerbear at fixya.com
Oct 02, 2010 | PfaFF Creative 7570
I upgraded to windows 7 and purchased the 2.5 upgrade for my ce-100 futura. I have not loaded any of the software. Which do I load?
Doesn't matter which you install. You'll have problems with Windows 7. Follow the following:
Sep 19, 2010 | Singer CE-100 Futura Computerized Sewing...
I need a driver for downloading futura 100 software on a windows vista home professional OS
Aug 16, 2010 | Singer CE-100 Futura Computerized Sewing...
I can't install Bernina Version 4 on my VISTA Operating system PC
As far as I know, Bernina version doesn't work on Windows Vista, you have to upgrade to the next Bernina Designer version which is Vista compatible.
Oct 01, 2009 | Bernina Artista 180
Janome Memory Craft 9000 Computerized Sewing Machine Logo
42 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
