Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
Water heats up but is not delivered to basket
I received a 12 cup coffee maker FTX45 at Christmas. I have used it every day but two days ago when it was turned on it just made a lot of noise and steam. The water was never able to get into the filter basket. I have tried several more times with no success.
  • 2 more comments
  • clemmobile Nov 21, 2008
    Same problem. It generates a lot of steam and noise and just "spits" very little water at a time into the filter basket. What should take 5 minutes to brew now takes about 20. We replaced our last coffee maker (same model) when it started to do this, but it was two years old. This one is practically new, purchased about a month ago! This is a serious defect that should be addressed by the manufacturer.
  • funakifamily Nov 26, 2008
    Same problem. Spitting, steaming and gurgling but no water delivered to the filter and thus no coffee!
  • Anonymous Jan 28, 2009
    Got the 12-cup coffee maker for xmas, and it just huffs and puffs without making any coffee.
  • Anonymous Mar 30, 2014
    I turn the machine on. The heater starts working. Some water is pushed through the coffee. Then I hear what could be the heater clicking off and the water stops going through the coffee. Only 1/4 to 1/3 of the water goes through the filter when there is coffee in it. 1/2 of the water goes through when there is no coffee in the filter basket.
  • 5,568 Answers
This may not help but doesn't cost much to try-
Make sure all water is out of the tank and dump a cup of cheap vinegar into the tank, turn it on until you hear some activity and then turn it off and ignore it overnight.
Turn it on in the morning and let the vinegar pump (hopefully) through and then run a pot or two of water before you try to make coffee.
There is a crappy plastic-body & ball valve in the line that is the first victim of lime deposits.
Once that little valve is stuck, it won't pump.
Plan on getting another coffeemaker in 3 or so years when another non-user replaceable part, the bimetallic thermal switch gets tired and it then takes a hour or more to make a pot of coffee.
Posted on Jul 18, 2008
Why won't it heat?
take it bak to bed-bath and beyond, and git another 1.
Nov 22, 2012 | Breville YouBrew 12 Cup Thermal Grind and...
Mr. Coffee FTX45, worked yesterday. The display and lights work. The water is not heating, so no coffee. What needs repair?
If you have an ohmmeter take the bottom of the unit off and check the thermal fuse for continuity that is the most common failure. It's located inside an insulated tube and clamped to the side of the heating element. If that is ok another clamp secures the thermostatic switch usually a porcelain body. When cold it should be closed or show zero resistance. The thermal fuses are available at Radio Shack but replacing it requires it's leads to be welded because solder melts at 350 deg F.
I have replaced them successfully by using crimp connectors available in the electrical dept. of your nearest auto supply. Hope that helps.
Nov 29, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Water does not pass through the Mr. Coffee. Just started out of the blue a few days ago. Heating element definitely works as steam just pours out the back of it but after running for 15 mins or so only...
Most of the time the coffee maker just needs cleaning with some Vingar sulution run though it.Do this about every 6 mouths.what happens specially with hard water it cluggs line up.So go to store buy small or big bottle of Vingar put about 1 cup in and half cup water aloud it to go though cycle's.Then or you may put two cups of vingar and two cups of water depend on how clugg it is.Then after done fill water despenser up to run Full pot like 12 cups,but donot over fill.that cleans it from the Vingar taste.You may want to do this twice.Hope this help,thanks for your question it was a good one.
Aug 08, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
My keurig seems to be heating the water all day???? normal brennantom@hotmail.com
Keurigs are ment to have water at the ready... otherwise... you might as well get a Mr. Coffee...
any Mr. Coffee will brew a cup of coffee... use a heaping teaspoon and add 12 oz or water...
May 02, 2010 | Keurig B100 Coffee Maker
Coffee maker with grinder--sometimes, when percolating, it overflows
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Jun 28, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Cusinart 12 cup grind and brew overflows with grinds and water
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
Apr 02, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Mr Coffee stopped brewing
Sounds like there are a couple of problems -
First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
The coffee maker is now ready for it's next use.
Jan 30, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
How to make coffee with 101-cup percolator urn (Regalware)?
Simply fill with COLD water to the number of cups desired.
Place the stem and basket in the pot and put one 8 oz cup of coffee for every 20 cups of water into the basket...when doing 100 cups I add an extra 12 oz of coffee for a good coffee flavor.
Place the perforated lid on the coffee basket that is in the pot (if there is a lid--some do not have a lid). Put the cover for the coffee pot in place.
Plug in.
Turn on if there is a switch.
Give these large pots about 1 minute per cup, brewing time...that is a little over an hour usually to brew 100 cups. The coffee maker will percolate with the water coming up through the stem and over the coffee as the water heats. Usually there is an indicator light that comes on when it is finished.
If holding the coffee for awhile, it tastes best if you remove the stem and basket and it will maintain the heat without doing more "perking" and becoming stronger or bitter.
Be sure to wash it out and dry it well, leaving the lid loose or upside down for storage so that the pot doesn't become pitted. Blessings, Louise
Nov 14, 2008 | Regal Ware 426473 Black Satin Coffee Urn...
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
457 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Jim London
Jim London
jmt
Level 1 Expert
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
