Question about ASUS P4T-M Motherboard
Installation integration for new cpu
I installed a new intel P4 1.9ghz processor and heatsink. I noticed that in the installation notes it says, 'Before installing the processor please consider integration issues found in the installation notes available on the World Wide Web.' My question is, what do I do about this and is it worthwhile to even bother about it? This is an upgrade from a P4 1.4ghz processor.
  • 449 Answers
Going to the website to view this details is not neccessary, as long as you know how to install processor on computer, it is very easy.
Posted on Dec 18, 2008
How to recover my intel pentium D 2.8ghz processor its over heating of 70 degrees.
If your system is five years old or older it is possible that the thermal grease/tape has dried and will need replaced. There is no need to remove the CPU for this. If you can enter your bios you can also check the fan speed of your CPU heatsink fan rpm. It should run between 2800rpm and as high as 3500rpm. If its not than replace your heatsink assembly.
Replacement heatsink assemble;
http://www.thefind.com/computers/browse-install-intel-cpu-heatsink
Thermal tape: http://www.crazypc.com/products/PQ5-5025.html
Thermal grease: http://www.newegg.com/Product/Product.aspx?Item=N82E16835100302&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-CPU%20Thermal%20Paste%20/%20Grease-_-MASSCOOL-_-35100302&AID=10440897&PID=1609763&SID=tfc_-_4_104_100921_e4d0767819e4422998638af41543c991:0000
Video how to remove heatsink assembly video how to replace heatsink assembly: http://www.youtube.com/watch?v=G3k9Ube9BBs
There are more videos listed on the right side of YouTube.
Good luck.
Mike
Sep 22, 2010 | Computers & Internet
How do i remove the processor on a dell optiplex gx 280 from the heatsink and repaste the processor seems to be like glued to the heatsink?
The heatsink compound does act as a weak glue over time. To remove the heatsink, twist gently after removing the clamps, to release the junction. The CPU should stay in it's socket. Scrape off the old compound and add new and re-install the heatsink.
Sep 23, 2009 | Dell Pentium IV 2.8GHZ Processor Unit...
Instal better processors ive one at 2.4 . i want 2 X 2.4 PROCESSORS on a asrock motherboard ,E5200 @2.50ghz, 2 gig ram,Pentium(R) DUAL-CORE CPU. How do i install this on motherboard
The CPU support list is here for you to check.
http://www.asrock.com/support/CPU.asp
If your MoBo supports the CPU you wish to fit, remove the heat sink and cooling fan, unclip the CPU and replace in the correct orientation. DO NOT attempt to force the CPU into the socket.
Also note you may have to upgrade the heatsink and cooling fan.
Sep 07, 2009 | Intel Computers & Internet
When I boot the machine it gives me a thermal overheat event msg and shuts down, I believe the thermal contact between the fan and processor has broken, I do not know how to remove the cpu fan and re apply...
Theres many types of sockets for motherboards. If PC clone, search for the book manual for pinpoint wath socket it it or it is a IBM or DELL or HP, the same except the latter is little more tricky when detaching the heatsink. Once figured out, disconect the power, touch the fuselage of the PC to discharge from ESD. Of course, buy a heatsink compound and you can clean the cpu and bottonm of the heatsink with paper towel and Isopropyl Alcohol and apply new compound. Not too much, the nessesary only. I'd like to apply in a whirpool like on the CPU. And the heatcopound color grey is the best.
Aug 21, 2009 | Intel D845GLLY Motherboard
PC Problem, p4 processor, intel D850GB . I think its the cpu
Decisions decisions. Sounds like threowing f=good money after nad to me. You could stilll have a problem after the new investment. If it was me i would be taking my money down the pc shop and buying a board to go! less hassle and cheaper in time and stress
Jul 29, 2009 | Computers & Internet
I have a new Heatsink & Fan Socket 478 C28085-001, but do not have an installation sheet. There is a square black film in the center of the bottom of the heatsink. My question, do yu remove that filme...
most likely yes because mine does not have film and the CPU can get extreemly hot so it would melt and it would smell very bad! so removing it is a good idea.
Jun 30, 2009 | Intel Computers & Internet
Changing a cpu on a compaq 5000T/REM
I've located this description when installing the pentium 4 processor on Windows XP. If you have not performed these steps this may be the cause of what you are experiencing. To save you time I've pasted the section below--> Operating System Support
Nearly all modern operating systems designed for the Intel Architecture have support for the Pentium 4 processor, although some may require specific versions or processor support files. Many Microsoft operating systems like Windows* 98 SE, Windows NT* 4 with Service Pack 5, Windows* 2000, Windows* ME, and Windows* XP support the Pentium 4 processor. Linux* distributions based on the Linux* 2.4 core support the processor. Also, many other vendors have support for the Pentium 4 Processor in their operating systems. System integrators should verify that the operating system they have selected supports the Pentium 4 processor.
Note: Windows XP or certain versions of Linux are required for Hyper-Threading Technology2 support for the Pentium 4 processor. For additional information on integrating systems based on the Pentium 4 processor supporting Hyper-Threading Technology, refer to the Integration Overview for Systems Based on the Intel Pentium 4 Processor Supporting Hyper-Threading Technology.
All operating systems that support the SSE instructions that were first introduced with the Intel® Pentium III processor will also support the SSE2 instructions introduced with the Pentium 4 processor. To experience the power of the SSE2 instructions, it is critical that system integrators install drivers and software that have been optimized for the Pentium 4 processor's SSE2 instructions. For example, for maximum system performance, system integrators using Microsoft operating systems that support DirectX* should load DirectX 8 (or higher).
Software Optimization
With specific drivers that use the SSE2 instructions, graphics accelerators, audio hardware and software, and other system resources can experience substantial performance gain. It is critical that systems also use APIs that use SSE2 instructions to achieve maximum performance. Two examples are Microsoft's DirectX 8 (or higher) and Open GL 1.2 (or higher). Most major graphics accelerator vendors have optimized drivers that use the SSE2 instructions. Graphics card vendors typically highlight support changes with new driver releases. Download and install the latest drivers (dated later than October 2000) from the vendor's Web site. Also, verify that the driver version contains optimization for the Pentium 4 processor.
Many applications also use the SSE2 instructions to experience the breakthrough performance of the Pentium 4 processor. System integrators should contact software vendors to verify support and determine version information.
System performance is greatly affected by proper operating system and driver installation processes. For example, it is important to install the latest Intel® Chipset Software Installation Utility immediately after installing most Microsoft operating systems to ensure proper drivers for the chipset are installed prior to installation of other drivers. System integrators should confirm boxed Intel Pentium 4 processor-based systems are optimally configured and integrated.
Conclusion
Boxed Intel Pentium 4 processor-based systems require proper integration. System integrators that follow the guidelines in this document will experience higher customer satisfaction by providing higher quality systems.
Please let me know if you have success with this.
Thank You, Raph30
Jan 22, 2009 | Compaq P4-M, 2.0GHz Pentium 4-M...
I just installed a asus P5N-D motherboard with a intel core 2 duo processor. On start up I get one long beep and 3 short beeps, nothing else. Unfortunately my motherboard book does not have the codes in...
Please double check the heatsink & cpu fan if its properly installed, sometimes the heatsink doesn't firmly sit or flat on the processor, and also try re-setting the CMOS.
-mrsolution
Jun 11, 2008 | ASUS Computers & Internet
Upgrading processor from 2.2 to 2.6
If the hsf isnt making contact with the cpu then thats def not a good thing!!! Luck its an intel cpu cos an amd one would have just burned out!!
Are you 100% sure the cpu is a compatable upgrade for you laptop as it sounds like it isnt if old one was "naked" but new one has IHS (metal heat spreader). Is it a laptop cpu u bought or just a regular desktop cpu?
Could you supply the codes written on both chips please?
Jan 07, 2008 | Dell Inspiron 8500 Notebook
ASUS P4T-M Motherboard Logo
52 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
