"LD" is a "Long Drain" error code. This is an indicaiton that you either have something lodged in the drainage system causing the drain pump not to drain, or your drain pump has failed. The washer will not complete the cycle until the condition that is causing the error is resolved. The Cabrio has two pumps. One is a recirc pump, the other is a recirc pump. The following link explains how to check the pump(s), or replace (if necessary):
http://www.fixya.com/support/r4155097-checking_drain_pump_whirlpool_cabrio
You can order parts (if required) from any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Make sure you use a complete MODEL NUMBER to ensure you find the correct parts listing. The first three sites listed also include exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. Prices vary between sites, so shop and compare.
If you do not find your model number listed at all the sites I have provided, use the part number from the Sears site for your search criteria. In some cases, the model number may not be listed, but the part numbers will.
If you have any questions, please post back and let me know. I hope you find this information helpful.
