Question about Husqvarna Husky 165
Chainsaw (Husqvarna 345e) will not start due to start attempt without adding oil to fuel.
If this was started without oil in fuel, then the piston is likely scored, and the compression rings stuck in a smeared aluminum mess. You can remove the muffler and probably see the damage to the piston. It can probably be repaired though. Take it to a reputible shop, then read the owners manual and get some help to learn how to safely use and maintain your investment that you have in this saw.
Posted on Mar 08, 2009
I have had my Husqvarna Emerald 122 for 5 years and have never oiled it, do I need to do that and how do I do it?
you need to contact husqvarna customer service and tell them
which model you have and ask them if the sewing machine is
self oiling or not.
Jan 29, 2013 | Husqvarna Sewing Machines
I dont know where to put the oil
There are small holes what you find along the moving parts indicating that it is a oil lubricating point. You might just have to use a tiny drop to get the oil to move along the holes to the spindle bearing/bush blocks or within the mechanism. Do not attempt to use too much oil but only if the machine is too dry as seem with a good lighting.
Happy New Year.
Dec 31, 2010 | Husqvarna Sewing Machines
Chain saw probles
chain oil tank is pressurised...release pressure before storing...but it will still drip some
Mar 09, 2010 | Husqvarna Designer I
My model 120 Husqvarna Viking sewing machine will not start sewing with vigor. It lugs through the first two minutes of stitching with virtually no power then very gradually picks up speed. How do I fix...
Repair manuals are available only to Husqvarna Viking authorized dealers. However, I have seen some on ebay from time to time. Sounds like your problem could be several things - binding of the internal drive shaft which may have a build up of grease and lint which unbinds as you sew, could be a faulty motor, or faulty transformer. Suggest that it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Jan 25, 2010 | Husqvarna Viking 1
Local Parts ?
Sounds like a chainsaw issue.........this is a sewing machine forum, suggest a re-post in a different category to get a sensible response quickly.
Sep 09, 2009 | Husqvarna Husky 165
Husqvarna 51 chainsaw will barely run, magnito and carberator ok
Probably need to re-adjust the carburetor jets. They are very small screws in the base of the carburetor. They will be labeled with an "H" and an "L" . Set the low speed first by turning it in slowly until the rpm drops slightly then start turning it outward untill the engine idles smoothly. At that point you can also adjust idle speed. Then you need to be careful here but you need to hold the throttle wide open at the same time adjusting the high speed jet. Turn it in until the rpm drops then slowly turn it out. The rpm will keep increasing. Once you get to a point where it is max'ed out then screw the jet back in one half a turn. Changes in altitude like using your chainsaw in town versus going to the mountains for firewood can sometimes make it necessary to adjust the fuel/air ratio.
Feb 18, 2009 | Husqvarna Husky 165
Husqvarna chainsaw repair
Usually empty fuel, use hook to pull out line , remove filter. Remove air filter cover and airfilter ,now you should be able to see line. Most just pull of carby and go through tank, some you may have to take screws out of av mounts in back of tank to see hole to put it back in.cheers hope this helps if where a stihl i could tell exactly.
Oct 29, 2008 | Husqvarna Husky 165
My Husqvarna 142 chain saw, new out of the box, starts and runs well enough but left to idle it continually stalls. Any ideas?
The carb needs to be adjusted. Look for 2 adjustments label High(H) and Low(L). Low is the one that you want. Start you chainsaw and let it warm up and turn the L adjustment a until you are able to let it idle on its own. Hope this helps.
Jul 07, 2008 | Husqvarna Husky 165
Sewing Machines Logo
167 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
