Question about Refrigerators
Maytag Refrigerator Ice Maker
Our new house has a Maytag RTD1900 top freezer refrigerator in it, for which we do not have the owner's manual. The freezer compartment has the option ice maker installed, and looks like it is plumbed in. We cannot figure out how to activate the ice maker. Any assistance would be greatly appreciated. Thank yoU!
  • 2 more comments
  • ginger27 Jul 11, 2008
    Thanks anyway, Mike. There isn't any metal arm to the right of the ice maker so perhaps we have a different ice maker. I did check to make sure the valve under the sink is turned on and that the line to the fridge looks okay, as well as checking the water tube behind the ice-maker. I appreciate your suggestions.
  • ginger27 Jul 12, 2008
    Hi, Mike
    Thank you so much for persevering with this question. It could be that the wire arm is missing because everything else seems to be properly connected in terms of the water supply. I will see if I can find the part locally or will try to send a digital photo of the ice maker as that may provide some additional assistance. Thank you again.
  • ginger27 Aug 24, 2008
    Here are a couple of pictures of the ice maker in our freezer compartment. All of the ice cubes have been made in ice cube trays, not by the ice maker--there just happen to be a couple of ice cubes on the mechanism. We can't seem to see where the metal arm mentioned in an earlier post would be inserted, or perhaps there is another suggestion. Any assistance is greatly appreciated.
  • Anonymous Mar 17, 2014
    ice maker
  • 481 Answers
  • first make sure the metal arm to the right of it is lowered, this turns the icemaker on.
  • then you can check the water supply to make sure it is turned on, sometimes when houses are vacant they turn the water off as a precaution. the valve may be behind the refrigerator or under the sink in the kitchen.
  • then...
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 04, 2008
  • 2 more comments
  • Mike Durland
    Mike Durland Jul 11, 2008
    so you think that the problem is something else? i was not helpful at all?
    according to the model number you provided, this icemaker should have a metal arm to the right side of it. this arm raises and lowers as it drops ice. so when the pan is full the arm cannot lower again and it stops making ice. if the arm is removed (very easily done) then the ice maker will never turn on.
    Item
    681233 at repairclinic.com $5.80
  • Mike Durland
    • none of my free suggestions have helped you at all?
    •  if you feel the issue with the machine is something else let me know, i will try to help you figure it out.
    Mike
  • Mike Durland
    Mike Durland Jul 17, 2008
    don't forget to increase my rating if i have helped you
  • Mike Durland
    Mike Durland Aug 06, 2008
My Maytag M1TXEMMWWB00 (209 cu ft) Top Freezer Refrigerator will not make ice. I checked the solenoid where the water comes in to see if it has a current and it doesn't (no juice). I looked at the owners...
The ice maker tells the water valve to open so you will not see the power until the ice maker ask for water. Does the ice maker have ice remaining in the ice slots? If not then fill with tap water and after the water freezes and ice maker cycles dropping the ice into the ice bin if it does not refill with water then you will only need to change the=> 2315576 Water Inlet Valve If the ice maker does nothing you will need to change the ice maker=> 4317943 Ice Maker Assembly You can find trouble shooting info at Appliance 911
, Thanks John Tripp
Feb 19, 2014 | Maytag M1TXEMMWW (209 cu ft) Top Freezer...
Maytag RTD1900 freezer working fine, refrigerator not cooling water dripping from top.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Refrigerators
New refrigerator, about 3 months old, have ice maker, but it makes hollow ice! any thoughts?
Check freezer temperature should be about at least 10 degrees or less but not below 0 degrees
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Maytag MTB2176 Top Freezer Refrigerator
We are hearing a sound like a clock buzz every 10 minutes. why
If your frig has a factory installed Icemaker and you never hooked it up to your water in your house, the Ice maker is looking for water. Shut off the ice maker by lifting up the metal arm on the ice maker. or unplug it.
Nov 17, 2009 | Maytag PTB2153G Top Freezer Refrigerator
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
Refrigerators Logo
1,311 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
