Question about Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Washer high spin shaking, AND high-pitched sound coming out of washer
We just got our washer delivered yesterday, I washed the first load of clothes, and it seems like the spinning drum inside is off-balance (the washer was NOT overloaded), it was a normal size load...and on the high-spin cycle, the machine vibrated and shaked and made a clink-clink-clink sound during high spin, also when I was done washing clothes, turned machine off, and there is this high-pitched sound coming out of the washing machine, it's some electrical sound, we unplugged it, and the sound went away, but it's a very annoying high-pitched sound! I think for what we payed for this washer, we shouldn't settle for these problems, I called Maytag, and the lady on the phone was an idiot, and we have the 5-year warranty on it, and also Lowes says they will replace the appliance within 7 days if defected, well this sounds defected to me. especially after spending over $900 on it, I think I should expect it to work properly! does anyone have any ideas what this problem could be? thanks for your time and help!
  • Ang42 Jul 04, 2008
    Thanks for the input, but yes, the shipping bolts were removed. I actually called Lowes and they are going to get back to me, and probably swap it out for a new one, it says on the reciept, they will replace any appliance within 7 days of delivery if it has a defect. It shouldn't be making a clinking sound when spinning, and there was nothing in there with zippers, it was actually more like a clunking sound than clinking. and ya, the constant high-pitched sound coming out of the machine when turned off, that's not right. Thanks for your help.
  • Ang42 Jul 06, 2008
    ya, actually they had the delivery driver manager come out and listen to a load run through, and he said run it through a few more loads and if those sounds are still there call back, because you need to be 100% happy with the product, he was very nice. but ironically, the high-pitched sound has gone away, and also the vibration and shaking of the machine has gone away, but now it's making a rattling sound on final high-spin. but the guy moved the machine over a little, and I think that the 1st delivery guy didn't put the machine in the right spot, mabye when he moved it over a little, he made it set on a better board support under the floor and made it more balanced. that high-pitched sound could have been a sensor sensing something was off-balance, that's my best guess.
  • 247 Answers
When someone reports severe vibration during spin on a brand new washer, the first question always has to be whether the transit brackets have been left in.
Washers are designed so that the drum and motor float on a collection of springs and shock absorbers. To prevent damage to these during shipping, a set of brackets is used to bolt the floating assembly to the case. If these aren't removed before first use (the manual will say how to do it) havoc ensues.
The irritating whine is a new one on me.
A.
Posted on Jul 04, 2008
  • Alastair Macleod
    Alastair Macleod Jul 04, 2008
    Sounds like the right way to go.
    With a new machine, trying investigations/repairs that aren't in the user manual just gives the vendor an excuse to dodge his warranty obligations.
    Good luck with the replacement.
    A.
Maytag Epic Z won't Drain after rinse cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
When the machine spins it shakes the whole house....Do they make rubber cushins to set the washer on ???
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 04, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic front load washer spin cycle sounds like an airplane is taking off
If you mean a jet aircraft, that is normal. Front loaders achieve amazing spin rates.
Feb 14, 2010 | Maytag MAH2400A Front Load Washer
Noise when high speed spin cycle
maytag washer makes a noise when washing or spinning. sounds like a screw is stuck or maybe a bearing is going. It is getting worse each day.
Dec 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z Washer has object between drum and tub.
did you ever find out how to separate the tub and basket on your maytag washer? I have exactly the same problem.
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag atlantis mav6000
sounds like the carbon brushes need replacing in the motor, they can cause a screeching sound as they wear down.
Oct 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Front Load Washer - Error F30
hI I HAVE REMOVE THE TOP COVER. YOU WILL SEE AT LEFT A PLASTIC ACTUATOR WHO MUST BE UNPLUG FROM ANOTHER PLASTIC PIN. JUST PUT IT BACK TOGETHER AND THE PROBLEM WAS GONE!
Jun 16, 2008 | Washing Machines
Maytag EPIC MFW9700S Front Load Washer Logo
632 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
