1999 Chevrolet Camaro Logo
Craig Sawyer Posted on Jul 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1997 Chevy Blazer with the 4.3 engine. The Service Engine light keeps coming on. I scanned the codes and replaced the O2 sensor just before the catalytic converter. The light is still coming on and the following codes are coming up: P0140 01/06, P0146 02/06, P0140 pd 03/06, P0146 pd 04/06, P0171 pd 05/06, P0174 pd 06/06. What do these mean and what do I need to do to fix the problem? Thanks, Craig
Jeff Armer
Level 3:
  • Chevrolet Master 15,575 Answers
  • Posted on Jul 23, 2017
Jeff Armer
Chevrolet Master
Level 3:
Answers
15575
Questions
Helped
7109049
Points
73899
P0146 pd means pending code
Pending codes and DTCs? Posted on November 12, 2010 by fcrmaster
When reading codes from your vehicle the fault code reader may show them as pending codes or normal Diagnostic Trouble Codes (DTC).
Pending codes (also known as continuous monitor codes) will be registered when an intermittent fault occurs. If that fault does not happen again after x number of start/stop cycles, the ECU will erase the code from memory. If the fault is persistent it becomes a DTC.
If you have read pending codes it is advisable to check the codes again after a week or so. If there is no apparent problem with the vehicle it is safe to erase the codes too and check back. But always make a note of any fault codes with the date and mileage of a vehicle.
If the codes read include a DTC then you need to investigate further. This you can either do yourself or advise your garage. If, again, you don't see an apparent problem (depending n the severity of the code) with the vehicle you can note the codes down and erase them. Then check again after a week or a few days depending on how often the vehicle gets used. If a repair has been made (previous owner) the DTC may just not have been reset after the repair.
The other numbers behind the code 01/06 , 02/06, 03/06 , 05/06 ,04/06 These don't mean anything . cheap code reader .
DTC P0140 HO2S Circuit Insufficient Activity Sensor 2
DTC P0146 HO2S Circuit Insufficient Activity Bank 1 Sensor 3
DTC P0171 Fuel Trim System Lean Bank 1
DTC P0174 Fuel Trim System Lean Bank 2
Sorry but this is something you should take to a qualified repair shop that has a diagnostic tool that can view sensor scan data.
Causes of lean condition trouble codes P0171 P0174 GM 5 3L
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Oct 24, 2008
SOURCE: diagonostic trouble codes reported p0171
P0171 is system too lean bank 1, P0174 is too lean bank 2, and 302 is misfire bank 1. Look for vacuum leaks. If you don't find them, put a vacuum gage on it can check. The P0171 is almost always a vacuum leak. If not other possibilities are front O2 sensor is too old and should be replaced (if mileage is greater than 100k then replace). Try injector cleaner. Misfires are usually bad spark plugs, but could possibly be caused by insufficient fuel. I've never had a car of mine in bad enough shape to have that error.
Anonymous
  • 3 Answers
  • Posted on Jan 16, 2009
SOURCE: 1999 ford taurus emission reading p0171 and p0174
just tune up ur car periodicly, clean filter. clean ur sparkplug.
Anonymous
  • 1902 Answers
  • Posted on May 28, 2009
SOURCE: Codes P0171, and P0174 bLean on a 98 Navigator. Any ideas?
O171 MAF (Mass Airflow Sensor) Just try cleaning this part it usually solves that problem without having to buy new part.
0174 Both are mass air flow sensors. The other problem can be a vacuum leak Check PCV valave and all vacuum lines. Also make sure fuel filter and fuel pump are working correctly. You can clean the MAF with some brake cleaner make sure it is dry before you install it back
Anonymous
  • 2049 Answers
  • Posted on Sep 10, 2009
SOURCE: p0171 and p0174 codes
P0171 System too Lean (Bank 1)
P0174 System too Lean (Bank 2)
If a car has a check engine light on and has P0171 and P0174 codes stored, the most likely cause is a vacuum leak. These codes are set by the car’s computer when it sees too much oxygen in the exhaust. Excessive oxygen readings in the exhaust will set lean codes. This does not mean that the oxygen sensors are defective. It is a common mistake for people to replace oxygen sensors when lean codes are present. Just because the code is related to oxygen sensor readings, it doesn’t mean that the oxygen sensors are bad. If both of these codes are stored this means that both banks of the engine have excessive oxygen in the exhaust. If the oxygen sensors are replaced it’s most likely that the same codes will reappear. It is very uncommon for two oxygen sensors to fail at the same time.
Therefore the most likely cause of P0171 and P0174 codes is a vacuum leak. The source of a vacuum leak can be one of many things. The most common cause of a vacuum leak is a leaky hose. Vacuum hoses over time can become dry and brittle. The rubber deteriorates and can leak causing a vacuum loss. Many times a leaky vacuum hose can be found by listening for a hissing sound. A large vacuum leak can even make the car run rough at idle. In some cases it will not idle without feathering the gas pedal.
Anonymous
  • 6 Answers
  • Posted on Sep 30, 2009
SOURCE: codes p171 and p0174 on a chevy truck?
Subject: 97-05 Vehicles with 4.8 5.3 5.7 and 6.0 Gen III V8 Engines and Misfires on One Bank - kw CEL diagnostics driveability DTC P0171 P0172 P0174 P0175 P0300 P0301 P0302 P0303 P0304 P0305 P0306 P0307 P0308 #PIP3056 - (07/12/2004)
Models: (00-05 Cadillac Escalade - C6 and K6) and (02-05 Chevrolet Avalanche - C1, C2 K1 and K2) and (99-05 Chevrolet Silverado - C1, C2 K1 and K2) and (00-05 Chevrolet Suburban - C1, C2, K1 and K2) and (00-05 Chevrolet Tahoe - C1 and K1) and (99-05 GMC Sierra C1, C2 K1 and K2) and (00-05 GMC Yukon - C1, C2, K1 and K2) and (03-05 Chevrolet Express G1, G2, G3, H1, H2 ) and (03-05 GMC Savana G1, G2, G3, H1, H2 ) and (04-05 Buick Rainier S1, T1 ) and (03-05 Chevrolet Trail Blazer EXT S1, T1 ) and (03-05 GMC Envoy XL XUV S1, T1 ) and (03-05 Hummer H2) and (04-05 Cadillac CTS-V DB) and (98-02 Chevrolet Camaro FB) and (97-04 Chevrolet Corvette YB) and (98-02 Pontiac Firebird FB) and (04-05 Pontiac GTO VB)
The following diagnosis might be helpful if the vehicle exhibits the described symptoms.
Condition/Concern:
Check Engine Light with a P0300 due to 2 - 4 cylinders misfiring on the same bank of the engine. DTCs P0171, P0172, P0174 or P0175 may also set for the misfiring bank.
Recommendation/Instructions:
If the published misfire diagnostic does not isolate the cause, perform the following suggestions as necessary:
  • Perform a fuel injector balance test for all 8 cylinders. If a fuel injector concern exists, it is possible to misfuel an entire bank of the engine, causing multiple cylinders on the same bank to misfire even though the root cause is a single fuel injector.
  • Inspect O2 sensor connections on the misfiring bank for corrosion or water intrusion. If water intrusion is found on the right bank, it may be due to the AC Evaporator Condensation dripping onto the O2 sensor harness. If this condition is found, reposition and shield the harness to prevent a repeat concern and repair the connections.
  • Check for excessive exhaust backpressure using the restricted exhaust diagnosis.
  • Swap the Position 1 O2 sensors side to side to see if the misfires move to the other bank of the engine. If so, replace the O2 sensor.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
NOTE: GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition.
1999 chevy blazer 4wd 6 cyc 4dr code P0420 Catalyst System effecency below threshold Bank 1 confirmed
There is a chance that your temp sensor is the culprit on both codes. The temperature sensor is what tells the ECU how hot or cool the engine is and weather or not to keep the engine in phase lock loop, or choke, mode. If the engine stays in phase lock it will run too rich and the O2 sensor will not be able to compensate.
9helpful
Meaning of po146 code for 1996 chevy blazer check engine light
Code -P0146 - o2 circuit no activity detected,
Bank 1 senor 3
Bank 1 is going to be where number 1 cylinder is at,
It's going to be the very last o2 sensor on the exhaust pipe, check make sure it's connected, if it is more then likely bad sensor.
1helpful
I have a 97 2 door tahoe. I have trouble starting it. It turns over but wont start right away. It takes about 8-10 seconds of cranking to get it to start. It will start right away if you push the gas down...
o2 is a sensor. You could try replacing the correct one (up to 4 o2 sensors are possible any given vehicle). If check engine light is still on, have the codes cleared, have scan performed again to get the fault codes for possibly the specific o2 sensor. Hope this is helpful.
1helpful
99 chevy blazer LS is popping out the tail pipe & carb code came up as po155
It is not a carb code as your vehicle has not carburetor. It is an OBD2 ECU code. What is means is that you have an O2 sensor heater circuit malfunction (Bank 2 Sensor 1). In your case I would recommend you inspect all the wiring going to that O2 sensor. If you find no problems then I suggest you replace the O2 sensor. The sensor to replace is on the passenger side, the sensor closest to the engine. This will more than likely fix your problem. After replacing the sensor reset the Check Engine Light. If the problem comes back then seek professional help and do not replace any other parts.
3helpful
2oo0 chevy blazer cel and code p0171 and p0174
Depending on the engine it will have between 4 and 2.
If you had a straight 4 or 6 engine then there would be only 2, one on the exhaust manifold or exhaust pipe and then one just after the catalytic converter.
If you have a "V" engine (V8, V6) then you have an oxygen sensor on each exhaust manifold and will have a catalytic converter for each bank of the V. There will also be an oxygen sensor downstream of each converter as well. In this case there would be 4 oxygen sensors.
I have a 1999 chevy blazer with a 4.3l I took the
sounds like you know what you are doing, sometimes the codes have to be removed after repair, i'm not sure whether or not your vehicle requires this. If it is just a light bothering you try and clear the code and see if it comes back. Some Advance Auto or O'reilly has a tool to do this free of charge
2helpful
Service engine light stays on after an oil change
The Service Light indicates that the EMC has detected and problem and needs to be addressed. Your going to have the get the Blazer scanned for DTC codes which could be a simple problem as to a faulty Gas Cap to a bad O2 sensor.
Sorry can not help you more then this but most large auto parts store like Auto Zone will scan your blazer for free and some auto shop charge as low as $10.00 to scan and reset the ECM.
Good luck and hope it's something simple.
2helpful
2answers
93 blazer runs better when check engine light's on
Could be a temp sensor or similar too, and believe it or not, the price to have the vehicle scanned for codes, and fuel pressure tested if necessary, usually ends up being cheaper in the long run, rather than play hit & miss, and replace a bunch of parts by guessing.
1helpful
1994 s10 service engine soon light
Have you had the truck scanned for codes? If so, what was the code, codes? Why did you replaced those listed parts. Can you hear any hissing noise coming from the engine or engine compartment?
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
