Question about GE GTS20ICNCC / GTS20ICNWW Top Freezer Refrigerator
Drain Hose Clogged on my GE Model No. GTS391CNBWW. How do I fix it.
  • 481 Answers
  • thoroughly clean out the freezer and pour some hot water in the very back of the freezer, this may unclog it. usually the clog is caused by an ice buildup.
  • personally i would take the machine outside and blast it with a hose, but thats just me. if you do this go ahead and do a thorough cleaning including the coils under the machine.
  • warm/hot water with a little bleach and dish soap (as a surfactant) mixed in works wonders when cleaning refrigerators outside.
Posted on Jul 04, 2008
My portable GE dishwasher is clogged and wont drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 13, 2011 | GE Profile 24 in. Built-In Dishwasher...
GE Triton 24
Hi
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Daniel
Jul 23, 2010 | GE Dishwashers
GE profile dishwasher (2004) will not drain properly. Is the drain clogged? If so, how do I open and clean it?
check the hose first alot of times the hose canbe clogged . disconnect the hose hit the drain on the machine and normally the clog will be seen. if that doesnt work then its the drain pump thats clogged.
Mar 06, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
DIshwasher drain clogged Haier dishwasher model DW12-PFE2-E
Remove the drain hose from the sink drain assembly and force air into the hose--The clog should spit out into the washer cabinet. Make sure the drain hose doesn't have any kinks or sharp bends. Hope this helps.
Nov 21, 2009 | Dishwashers
GE Model gsd5330d00ww will not drain. There are no drain obstructions and I have replaced the piston gasket in the rear of the tub. What is my next step in figuring out the problem?
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/control
Replace if defective (note: uncommon problem).
Jul 30, 2009 | Dishwashers
I have a GE TBX25PAXCRWW top mount freezer model. It is leaking water from the light switch. I would assume it is a blocked evap line. Do I access it from the insde of the freezer or outside.
Your problem is a clogged defrost drain . This is accessed from inside the freezer section and by removeing the rear freezer panel . Use a hairdryer to defrost the pan , under the coils . Also , the drain line for your model , is located behind the refrig . So , you only have a short area between the drain hole and drain line , to clear . I would suggest blowing thru the drain hose behind the refrig also , to make sure it is clear .
Jul 02, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Clogged washer pump
you have to take out the little motor that drains the water and clean it up , first you open the front panel or back panel depending of the model , second follow the DRAIN HOSE to where its attached to the DRAIN MOTOR , remove the motor for cleaning , its probably clogged.
Apr 05, 2008 | GE WBSR3140DW Top Load Washer
Dishwasher will not drain
I hav an Americana / GE dishwasher, only one and a half years old. the dishwasher is not draining. When I turn the selection knob on the front to wash, is begins filling with water again. But, the cycle is not actually working. I removed the drain hose from the disposal unit and allowed the really really nasty collection of water to drain out. I have a feeling that the hose connection to the washer is clogged. Is this possible. If so, should I remove the hose from the connection at the dishwasher and clean the hose or could it be something else.
Thank you,
Aug 31, 2007 | GE 24 in. GSD4320Z Built-in Dishwasher
Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Aug 16, 2007 | GE WPGT9360EPL Top Load Washer
Open Questions:
See all GE GTS20ICNCC / GTS20ICNWW Top Freezer Questions
GE GTS20ICNCC / GTS20ICNWW Top Freezer Refrigerator Logo
222 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
