Question about Garmin nuvi 200W GPS Receiver
Unit doesn't work with vehicle power cable
The unit works properly on battery power, but as soon as you plug in the vehicle power cable, the screen shows a picture of the unit plugged to a computer tower. I've tried resetting, and that didn't fix the problem.
  • 5 more comments
  • jnugent Jul 09, 2008
    Same problem. When product plugged into adapter it shows as being plugged in a computer.
  • hayden386 Jul 12, 2008
    Same problem. Unit works when not plugged in but get that same symbol when connected to power in the car.
  • kfirestar Aug 07, 2008
    My unit won't work either when the supplied cigarette lighter charging plug is plugged in. It shows a computer symbol on the screen and will not work unless unplugged and run on its own battery power. I would appreciate someone getting in touch with me kfirestar@hotmail.com if they have found the answer. Thanks ever so much. Greg
  • Anonymous Aug 22, 2008
    Same Problem - and now the battery is dead and it does not seem to be charging as it will no longer turn on at all!
  • Anonymous Dec 01, 2008
    Same problem , fidoliedo - what sort of answer was that a design flaw ! ,
  • BillRS Dec 06, 2008
    Yes, I have the same problem, I charged it using a USB, now when I plug it in to the car adapter, I get the 'computer tower pic'. So what do I do to get around it? (besides unplug it and use battery?
  • Anonymous Apr 22, 2009
    didn't have this at first, now do. must be a way to resolve
    Scholar:
  • 162 Answers
If you are using the USB cable, that won't work. You must use the bracket plug. the USB cable will charge the unit and you can't use it while it's charging. If using the USB, the system thinks you are either charging the unit or connected to a computer. This is a design flaw.
Posted on Jul 25, 2008
Same thing here...won't work when plugged into car charger (or PC), but works fine in battery mode
Posted on Apr 15, 2010
My Garmin nuvi 265 was working fine until 2 weeks ago. We got a screen message saying that the XM traffic was not supported, and then noticed that the unit no longer could be charged using the car...
The traffic receiver is in the car charger cable. The charger should have a red light on if it is getting power. If the light is on and the unit is not charging and you have no traffic, the charger cable is bad. If the light is off, then either the fuse did not fix the problem, blew again, or is somehow not sitting properly in the charger. Another thing you can check is by using the unit in another vehicle. If it works fine there, then the charger is not making good contact with your vehicle outlet for some reason. You will probably have to buy a new traffic receiver charging cable.
May 04, 2017 | Garmin nuvi 265 Car GPS Receiver
My gamin won't charge
FIRST, make sure you have the charger recommended by Garmin. I made the mistake buying a cheap brand and it didn't work. That was a waste!
Next:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Jan 18, 2010 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 260W will not start up. When not conneccted to power, unit attempts to start up, shows Garmin logo, then copyright logo, then "loading maps", then goes blank. When connected to power, the unit...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu. clip_image001.jpg clip_image002.jpg
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on. Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on.
If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
Jan 09, 2010 | Garmin Nuvi 660 GPS Receiver
My nuvi 205 garmin stops working s soon as I
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First Make sure your plug and power cord are working. USE a Garmin charger!!!!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece.
  1. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  2. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
Nov 01, 2009 | Garmin nuvi 205 GPS Receiver
My nuvi 260 will not display anything . It turns on okay with the Garmin introduction and then screen goes blank
Sounds like a battery problem. You may have to send to Garmin for replacement of the battery as it's not user fixable. I also highly suggest using a Garmin approved charger/ car charger if you don't have that!!
Or understand this:
Oct 06, 2009 | Garmin nuvi 200W GPS Receiver
Battery on my garmin c510 sat nan wount hold a charge how easy is it to change
Had the same problem. Fixed with a new battery. Takes the same as a Streetpilot c530 and can be purchased anywhere on line. A 10 minute job with a soldering iron.
1. Open face plate. Unscrew 4 screws. Remove battery connector and clip.
2. Unsolder the wires to the two speakers - 4 wires.
3. Remove the sticky wrap from the old battery and place around the new one (to stop it rattling).
4. Solder back the new speaker wires.
5. Plug in battery, reassemble unit and charge Garmin off PC wih usb cable.
Done!
Sep 15, 2009 | Garmin StreetPilot C330 GPS Receiver
IPAQ hx 2110
You may need to purchase a new internal battery
Feb 04, 2009 | HP iPAQ H2200 Pocket PC
Screen problem with HP DV 9000
I think Your computer C.P.U. power supply unit is not working properly. because these type of problem occur when Power Supply Unit is not working properly.........
So Don't afraid at all just change your c.p.u. power supply unit with new one (it is not costly at all).
Mar 19, 2008 | Computers & Internet
I have a nuvi 200 that wont run when it is hooked up to a power supply
Vehicle Power Cable to the nüvi and connect the otchapin.screen1.jpgher end to your computer, your nüvi does not operate as a GPS unit - it goes into some sort of charging mode. However, if you FIRST turn on the nüvi in the battery mode then go into the test mode (press the battery icon for about 8-9 seconds) from the main screen, THEN PLUG in the USB cable, and finally exit the test screen, your nüvi will restart chapin.screen2.jpg(reboot) and it will operate just like it was plugged into the cradle connection in your vehicle.
This mode will charge the battery
AND operate as a GPS.
It works with my computer USB cable, my cell phone charger and my car charger for my cell phone.
Don't forget to turn off the nüvi before unplugging."
Mar 01, 2008 | GPS
Garmin nuvi 200W GPS Receiver Logo
980 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
