Question about Eiki LC XNB3 Multimedia Projector
LC-XNB3 won't turn on
My projector counted down to zero and turned off and now it won't turn on. The fue is good
  • mbrown1 Jul 04, 2008
    The "fuse" is good
  • 682 Answers
Check lamp compartment cover and confirm that it firmly closed-check power cord and power in outlet(electricity)
Posted on Jul 08, 2008
How can I find the bulb life remaining?
1,turn on the projector
2,press and holding down "UP" for 20 seconds,
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Mar 05, 2014 | Eiki LC-XB28 XGA LCD Projector Multimedia...
Why won't my warning light turn off?
Probably a fan that doesn't rotate, or one of the many sub-voltages is absent on the mainboard due to short circuited capacitors ( SMD's)
Oct 25, 2012 | Eiki LC-SE10 Projector Multimedia...
After putting a new lamp in the projector in my PT-AE1000U, it turns off on it's own after 5 to 8 minutes of use. I was told it could be a BIOS setting that counts the hours of use that needs to be zero's...
Generally speaking a lamp timer is just a warning indication and won't shut the unit down. There should be indications of why the unit is shutting down. For example, is the power LED blinking or any other light blinking? My primary suspicion would be either an air flow problem or heat. Check to be sure that the fans are running properly.
Please update this with any additional detals.
Thanks,
Dan
Apr 25, 2011 | Panasonic PT-AE1000U LCD Projector
I have an eiki xbl20 projector that i mounted upside down. How do I get the image to turn right side up?
Nov 20, 2009 | Eiki LC-XB15 Multimedia Projector
I have a eiki lc-xnb5m projector that seems to be shutting down if it's ceiling mounted, but runs fine on a cart. I know it sounds strange, but, is there some sort of gravity sensor or levelling sensor or...
there is a heat sensor, i had a same problem, and it turned out to be this dumb thing, if projector get's to heated up it shut's down to save the electrical components from burnig out
Oct 29, 2009 | Eiki LC-XNB5M projector lamp Projector...
EIKI LC-XNB3 Projector - Does not recognize any Video Inputs
there might be a bad connection between the input board and the main board. There are different connectors ( white) between them, that might be damaged during portable use
May 24, 2009 | Eiki LC XNB3 Multimedia Projector
Eiki LC-XG110 lamp going off
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
May 13, 2009 | Eiki LC-XG110 Multimedia Projector
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
Bulb Life
hi,
This is 2000 Hours, 160 Watts, UHP lamp. dont keep it on always.Check the usage and then replace the lamp. It's better to turn off the projector after each class.
The lamp is around $400.00 for Eiki LC-SD15.
Viren
Rave Services India
Feb 07, 2008 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Problems changing lamp
Try removing the new bulb and reinsert it and make sure it make a good connection. Be sure to follow your projector's instruction manual on how to change your bulb exactly.
May 19, 2007 | Eiki LC XNB3 Multimedia Projector
Eiki LC XNB3 Multimedia Projector Logo
120 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
