FixYa.com
Tags:
Dishwashers
Generic problem for all Dishwashers
Jammed disposal (in sink erator) (by 2 users)
posted by lilpeltzpe on Jul 04, 2008
Jammed disposal (in sink erator) i believe a nail was lodged there. it came out but it still doesn't work. Had a allens wrench and hit red button and it still doesn't work
Comment by lilpeltzpe, posted on Jul 05, 2008
Thank you :after reading your advice it makes great sense .You have saved me time and $$
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by khudaafiz, posted on Jul 30, 2008
The disposer when on gives a stuck sound and the blades are not turning. I cleaned the blade area and also pressed the red button. Couple of times it strated briefly and then it went back to the stuck sound with the blades not turning.
Best Solution
Helpful (85)
aehess
Rank:Wiz Wiz
Rating: 85%, 66 votes
If you can turn the disposal by hand with the allen wrench and you press the button and it still won't work try checking the house fuse or circuit breaker. If you have power at the disposal and all of these things fail just buy another disposal. (usually under $100) Buy the same brand and you won't even have to replace the fitting in the sink If you buy the same HP the plumbing won't even have to be changed. In sink erator makes Emerson, some Kitchen aid, some Whirlpools and most Sears Kenmore disposals. You should be able to look and tell if it is the same size. It is cheaper to replace than call for service. With the same brand it won't take more than 20 min to install. Read the instructions you'll see how easy it is. (if your dishwasher drains through the disposal make sure you remove the knockout plug before installing the disposal.)
Rating Locked! (?) lilpeltzpe has rated this solution as Helpful
Solution #2
posted on Aug 18, 2008
Not Rated (0)
jw900
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Mine has a different problem. The erator works. But there is a hole outside the erator, as if it is eroded. When I touch it, crumbs fall.
What is this problem? Shall I use something to seal it?
Thanks.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Bosch 24 in. SHU43 Built-in Dishwasher Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher GE Nautilus 24" Built-in Dishwasher Bosch 24 in. SHX36L05UC Stainless Steel Built-in Dishwasher Bosch 22 in. SKT5102 Free-Standing Dishwasher
Can you Help with these Dishwashers problems?
Dishwashers
bosch dw model shu3002 The
bosch dw model shu3002 The... Answer This...
Dishwashers
Nardi Dishwasher: stops before...
Hi, can anyone help me with... Answer This...
Dishwashers
The water is not draining
The water is not draining from... Answer This...
Dishwashers
when it goes through the
when it goes through the wash... Answer This...
Hoover 24 in. DT999 Free-Standing Dishwasher
hoover dt999
dishwasher makes loud pop/bang... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
