Hi Trevarth,
The Optiplex GX 260 was outfitted with either Integrated Intel Extreme graphic or a 4x AGP video card. In either case if you try to change the resolution and 1920 X 1200 is not an option, the video card does not support that high of a resolution. If you want the higher resolution you will have to buy an AGP video card. When selecting a card, look at the specs and make sure that the higher resolution is supported. The good news is that AGP cards are not that expensive. Here are a couple site you can find video cards.
http://www.nextag.com/4x-agp-video-card/compare-html
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&name=AGP%20Video%20Cards
You can find very cheap used one here:
http://www.google.com/#q=4x+agp+video+cards&hl=en&safe=off&sa=X&tbs=shop:1,p_ord:p&prmd=ivns&fp=a9f29339130ebba7
but be careful to check the specs before you order.
Hope this helps
Thank you for the reply 7Sleven. The gx260 does have the Intel extreme graphics on board. I think I will have to go down the used route as a lot of the modern cards here in the U K need at least 300 watts power supply.
Many thanks.
