Question about Proview PL926WBi 19" LCD Monitor
Olevia Monitor When I power up and turn on monitor, I get a blue screen with a message in top right corner "Not support". I made sure all connections were good, rebooted, and I get the same message, and nothing else appears on screen.
  • 3 Answers
Restart your computer and tap the F8 key until you get the Windows Advanced Options Screen. Use the arrow keys on your keyboard highlight Enable VGA Mode (Low Resolution Mode for Vista). Press Enter. Then Enter again.
Windows will boot up in a low resolution which will make things look large. Raise your resolution to a normal level in Windows' Display Properties (in the Control Panel)
The next time you restart the computer, it will boot normally.
Posted on Jul 15, 2008
When I connect my monitor to my lab top the green power light comes on then turns orange and I get "no signal" message on the monitor
you may need to tell the lap top to display from that screen the new screen has no image or signal so goes to sleep to save power.on your lap top try the (FN) key on your laptop then select a blue picture on the keyboad of to squears one black one blue this will alter the display.OR in windows look at Start>controal pannel>display
Jun 03, 2010 | Sharp LL-173C-B (Black) 17" LCD Monitor
My monitor will not go back on. There is a green light blinking
Hi ,
In order to isolate whether its the monitor or the compurter tower you can do a self test to check if the monitor is fine .Turn the computer off and then disconnect the cable for the monitor from the back panel of the computer tower.It will be a blue connector with screws on it .Undo the screws and then disconnect it then turn the computer on ,if the monitor is fine you should get a message that would say check input signal or you will have some kind of message on the screen that tells you that the data cable to the monitor is not connected.If u dont get any message that simply means that the monitor has gone bad and needs to be replaced...
hope this helps you .....all the best
May 12, 2010 | Acer AL1916W 19" LCD Monitor
Monitor doesn´t work
1 MAKE SURE THE DATA CABLE IS CONNECTED TO THE CPU.
2 MAKE SURE TO TURN THE MONITOR ON.
Aug 05, 2009 | Samsung SYNCMASTER 943B 19" LCD Monitor
Out of range message
check the unit/CPU to the others monitor or open then make a clean the VGA card and Memory..good luck
Jun 25, 2009 | X2Gen MG17J 17" Monitor
Olevia 540-B11
damm i have the same issue except the left side of the screen is far darker than the right. It still works but is very noticable. If you get this resolved please reply back!
Aug 19, 2008 | Olevia LT42HVi 42 in. LCD Television
Blue rectangular box appeared on monitor and won't go away
Try pulling the AC plug out and leaving it overnight.
The processor may have tripped over itself.
Jul 30, 2008 | Olevia LT32HVM 32 in. LCD Television
My screen is broken
It won't turn on, it's showing only blue, there's an error message, it's literally broken, what?
Is it a laptop screen or a desktop monitor? If it's a laptop screen, you'll probably have to buy a replacement. If it's a monitor, make sure the power cord is plugged into the wall and the back of the monitor itself, and that the monitor is connected to the tower.
May 03, 2008 | Computers & Internet
Demagnetize computer monitor
It looks more with screen resolution problem, if it is new then the best option is get it replaced.
Dec 12, 2007 | HP mx705 17" CRT Monitor
Olivia multi-media TV/monitor
Not really. Repairs are right about $150 - $250. Resistor Kit, Caps., maybe other parts, and labor charges.
Jun 27, 2007 | Olevia MN-20LCDTV-SN 20 in. EDTV-Ready...
Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
75 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
