Question about Sony DCR-HC19E Mini DV Digital Camcorder
Sony Camcorder Mini DV tape doesn't go in
I have a Sony Mini DV camocorder which is about 3/4 years old. It has been woring fine all this time. 2 weeks ago when i tried to use it, i realised the tape is not going in after shutting the tape opening. After several attemps somehow at one point it went in and i thought the problem was over but when i tried to use it warned me that the tape needs to be inserted even though the tape was inside. I tried Sony/Non Sony tapes as well but the problem still exists.
Can you please help.
  • condi Jul 14, 2008
    Do have the same problem when i try to insert cleaning tape.
    After several attemps only i can get the tape to go in however the camcorder doesn't always recognise that the tape is in.
  • Sony Master
  • 2,794 Answers
Have you cleaned the tape deck at all? That might work.
Posted on Jul 04, 2008
  • Tim Babcock
    Tim Babcock Jul 14, 2008
    It should go to a repair center to see what the problem is.
DCR-HC26 will record but will not play
There are two solutions, one, buy a mini dv tape player. They are kind of expensive, but you will be able to get your information off your tapes. Second, buy a used, working mini dv camcorder on ebay and use it to get your information off your tapes. A five year old camcorder is not work fixing.
Jan 27, 2013 | Sony DCR-HC26 Mini DV Digital Camcorder
Hi,i have several question i want to ask regarding my Sony Handycam DCR-HC28 Mini DV Digital Camcorder. 1)How to connect my camcorder with my laptop,my computer is old sony vaio VGN-CR22 G/W? 2) If the...
Fire wires are available for almost all cameras, they are easy to get at the local electronics store or on line, I buy mine through ebay. All you need is the model number of the camera and the salesperson can locate the cable you need, or better yet take the camera with you and let them match it up for you. try radio shack. Most computers have the software for the transfers already installed, there are a ton of software options out there to use just look for one that fits your price range. I use Nero and it is available on line or in stores. you can't record without the tape, there are no hard drives in this camera to store video. You can hook the camera up and record directly to the computer through the fire wire. The tapes can be used over and over again till they start to wear down, but you should easily uses these 10 times or more before getting an new one. I doubt any store will take a trade in, maybe a small family owned store could work with you, or maybe a pawn shop. The laptop probably will not hold a lot of video in the memory but you can burn these on to a DVD disc using either windows or Nero.
Dec 05, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
No picture when trying to record
Check the following link. Call them and explain the symptoms and they should send shipping label to you so you can send the camcorder in for repair. I had my TRV38 repaired in about 2 weeks. Good luck.
esupport.sony.com/perl/news-item.pl?mdl=DCRTRV19&news_id=95
this is a known issue with Sony
Apr 20, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
DCR-HC42 will not load Mini DV
Have you all tried using a new battery? It happened to me before where I would try and load the tape and the motor just hung and wouldn't allow the tape to fully go in. I tried to recharge the battery to see if that was the problem and even left it plugged in but camcorder appeared to still be weak. I think went to Wolf's camera and asked if I may if a bigger batter would feel weird with my current camcorder (I just said that so I could see if I could borrow a new battery and see if it would fix the problem). When I installed the new battery, it loaded the tape with no problems.
Try it and tell me if it solves the problem.
Nov 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Gray lines on clips while previewing
Hello Nick, please purchase special mini DV tape for head cleaning. After a treatment with this tape you can check if there is an improvement with other tapes. If you need more info please advice. Arpi
Aug 12, 2007 | Sony DCR-PC55 Mini DV Digital Camcorder
JVC GR-D370 Mini DV Digital Camcorder
Usually when the recording is started it takes around 10 to 15 seconds for the camera to recognise and display the duration of remaining tape, if you feel there is a problem, try using different brand tape.
Mar 17, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Sony DCR-HC19E Mini DV Digital Camcorder Logo
65 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
