Question about Sony MHC-RX66 Shelf System
Programing the radio stations
I have a Sony MHC-RX66 Shelf system. I am trying to program radio stations such as FM-1, FM-2, FM-3 etc. How do I program the stations.
Thank you
Don Jones
D10Sparky@aol.com
  • acf81 Sep 09, 2008
    Me too. I also can't get the volume knob to work, volumes can only be adjusted by the remote
    Problem Solver:
  • 4 Answers
You just press the program button on the front of it. It's next to the Stereo/Mono button!
Posted on Oct 26, 2008
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
Coaxial FM antenna
Radio Shack has an
adapter catalog number 278-0291. It takes some effort to push the 278-0291
adapter onto the FM UNBL 75 ohm terminal so wait until you have the 278-0291
installed before you connect your 75 ohm coax on to your new adapter.
This will resolve your FM screw on F connector antenna interface issue.
I see others trying to
help suggest using a 300 ohm to 75 ohm transformer match unit, this isn't what is needed. Your receiver antenna input IS a 75
ohm input.
May 22, 2013 | Sony MHC-GX450 CD Shelf System
I knave a teac model ex cd3. Have lost the manual. Can't remember how to reset the radio stations. Can you help?
OK press power on,select tuner button for radio. then select band AM or FM. Then press tuning mode button until you see [manual] in the window. then press the tuning button [arrow left or arrow right buttons] until you get to your desired station.then press program / memory set. a memory number will flash [ say memory 1]. then press program/ memory /set button again to lock in the selection [memory 1] now this is the TRICKY PART. Once the selection is memorized go back to tuning mode Press the tuning mode button until you see manual and i think you can follow the above procedure. If you program AM stations first Then press the BAND button to get FM stations and go back to step one.
Feb 17, 2011 | Teac EX-CD3 CD Shelf System
I have an Sony RX66 the cd changer will not pop to play on.
My sony stereo rx66 after finish to play the first cd stand of going to play the second one, it put the cds one of the top of the other or under the tray. Can somebody help me?
May 04, 2009 | Sony MHC-RX66 Shelf System
Can't plug laptop to SONY MHC-2800
You need to plug red and white cable in MD/DAT OUT connections and then press MD/DAT button on the front panel.
Feb 22, 2009 | Venturer CD2770 CD Shelf System
How to store a radio station
On most Radio Systems do the following:-
use the tuning buttons, + or - to find the wave length for the required radio station
Once you can here the station, press the button for the number where you want to store the station and hold it down until you here a beep
Do the same for other radio stations on the other numbered buttons
thanks HPC
Jan 17, 2009 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
MHC-GX250 Sony AM tuning doesn't work
Check the wires in the back and make sure the antenna wire is still connected!
Jan 03, 2009 | Sony MHC-GX250 CD Shelf System
How can I add stations to the memory of SONY MHC-C33 Shelf system
Download user manual of MHC-C33 from Sony Support and get to know this system properly.
Thank you.
Dec 01, 2008 | Sony LBT-LX50 CD Shelf System
FM Radio doesn't work
it may be that the fm detector has failed or possibly a tank(tunning coil)
Aug 31, 2008 | RCA RS2664 Shelf System
Sony MHC-RX66 Shelf System Logo
288 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
