Take off the front kick plate (bottom panel) then remove the front panel. The top panel will be attached to the front panel by some plastic push in retainers you can loosen with a screwdriver. The belt will go around the drum on top to a drive wheel at the bottom of the machine. you will have to slip the belt around the drum in the front or back of the drum to get it around it.
