Question about RCA P46921 46" Rear Projection Television
P61940 Sound but no picture
Cable input. Cable output works fine on other portable tvs I have.
  • rickm352 Jul 04, 2008
    Tried that also.
    Tried but no help. If you'd like I can call you or you can call me. I'll pay for any charges if there are any.
  • 2,326 Answers
If you have a VCR or a DVD player, connect the red, white and yellow cables to the TV and select video 1 input on the TV.
Let me know if you require further assistance.
Posted on Jul 04, 2008
  • Jaime Hernandez Jul 04, 2008
    I'm at work right now but you can call me after 6:00 PM Eastern time. My cell number is 416-829-2760.
ProView has a bad cable connection. Other tvs hooked to the same cable don't
It could be the tuner in the set is the problem--there is since the rear inputs work fine a way to "get around this".
Get a Cable box that has the audio/video outputs on the rear and connect to one of the rear inputs on the set--want to watch cable--go to that input and use the box to change channels.
If the tuner is bad you are likely going to have to replace the entire board it is on--not cheap.
The rear inputs bypass the tuner and all the signal circuitry from it.
Also if signal routed via rear jacks you should notice a better picture and sound quality.
SD TECH
Apr 22, 2012 | Proview PA-32JK1A 32 in. LCD Television
I tried hooking up my laptop to my 37lh20 tv. I connected the avi to the pc input and an audio cable fro the headset jack on the tv. If I put the tv input on rgb pc I get the picture but no sound and if...
Unless you hook HDMI to HDMI, you won't carry sound across the HDMI cable. If you're using a VGA to HDMI converter, you'll get the picture but no sound.
I have a feeling the headset jack on the TV is an output rather than an input. Most TVs accept HDMI, RCA, or a digital audio input (either coaxial or optical). Unless you have a S/PDIF optical output from your laptop (and you obviously don't have an HDMI output), then your only other choice is likely to get a cable that splits a 1/8" headset type connector into two RCA plugs that you'll plug into an AUDIO IN input on your TV.
Jul 14, 2011 | LG 37LH20 37 in. LCD HDTV
I have a panasonic Viera and I'd like to play my computer through it. The computer picture works fine through a converter to the HDMI cable input but how do I get sound? I need a separate cable from the...
does your computer graphics card have a hdmi output on it? i had a same problem the coverter input will not let sound though it u would need a hdmi output from the computer or need to connect a separated sound output as the form of speakers from the computer itself, i mite be a problems with drives, try updating the graphics card drives. this mite solve the problem as well. hope this helps
Aug 13, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
XBOX 360 composite output works fine. Component
You say the component video is no good? Well this usually happens when it is wired up incorrectly, Ensure you have the right colors in the right jacks at each end, it is real easy to get mixed up... make sure Red goes to Red, Blue to Blue and Green to green, all alongside each other, NO ALSO using Component you MUST also run 2 more cables for the Audio, they are Red & White NOT the Red from the "Other" Video input, BUT the AV Red & White jacks, beside each other on the units. So all in all there are 5 cables taking the Video, 3 R, G, B. + The Audio, R & W.
Mar 02, 2010 | Microsoft Xbox 360 Console
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Jan 12, 2009 | Yamaha RX-V661 Receiver
No picture, have sound
Sounds like the video cable from the receiver to the projector is disconnected. Check the video output cable on the receiver and the video input on the projector. If they are connected all the way then unplug them and plug them back in to see if that works. If it does not there is probably a break in the cable somewhere or something not set right on the output or input on the receiver.
Jan 02, 2009 | Knoll MA250 Amplifier
RCA P61940 No picture but sound ok.
I've anwsered on your premium post.
Try using the audio/video inputs to bypass the RF converter (tuner).
Jul 04, 2008 | RCA P61940 61" Rear Projection Television
RCA P46921 46" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
