Question about Hyundai ImageQuest L17T 17" LCD Monitor
Imagquest L17t have not power
My monitor is going black, and I can see, that there ar no power on it.
Now I have opened the monitor, taken the cover off and the prints are fre, but I can`t find the fuse. Are there any, there has a diagram, there show the fuse. And if there aren`t a fuse, come with solutien to clear the problem with the monitor
Thanks
Niels Peter Nissen
  • Nissen Jul 05, 2008
    it is a imagequest monitor L17T
    Niels Peter Nissen
  • Nissen Jul 08, 2008
    How can I get a repair/service manual
  • 2,326 Answers
The service manual can be download it from this website. Make sure to downlaod both parts and unzip them using winrar.
I've check the service manual but does not have the complete power supply circuitry.
The fuse will have a letter "F" follow by a number.
Posted on Jul 08, 2008
    Master:
  • 788 Answers
In my opinion the current price of LCDs is so low that you may end up putting more time and money into your 17" than it warrants. Dell has 19" widescreens for $209 and 20" widescreen for $234.
    Master:
  • 726 Answers
Http://www.hyundaiq.com/pro_l17t.asp# here is a website on your correct model everything u need to no the fuses are on the circut borad but not really for users to get to them if its under warrenty great other wise a repair shop can fix the fuse for around 20 to 30 dollars
Posted on Jul 05, 2008
    Guru:
  • 859 Answers
The fuses on these boards are not user serviceable. They are little elements on the circuit board and may be noticed by their scorching. However, when one blows, others cascade and all parts to the circuit board in doubt should be replaced.
If you are under warranty attempt replacement. Otherwise, it is not worth fixing given that you can get a refurbished model for less than the cost in labor to fix yours.
Regards, and sorry to bear the bad news.
Worldvet
Please remember to rate all our solutions on Fix Ya.
    Sergeant:
    Champion:
  • 417 Answers
All i Can Say Is The Fuse Should Be On The Power Board Sometimes there are a little white or black box that shields the fuse beneath it
  • 13,433 Answers
The power adapter board may be bad, there may be no user replaceable fuse there, would need a repair / service manual.
    Brigadier General:
  • 3,614 Answers
May i know the exact model # of your monitor..?
How to open gateway FPD 1765 LCD CASE OR BACK COVER
At Last! Okay this is how you open a Gateway FPD 1765 monitor. This Monitor open from the front first to reveal 4 screw under the black trim. Lay the screen face up, NOT FACE Down. So that the GATEWAY LOGO is looking at you. Carefully, lift up the black plastic trim slide a knife or slim tool, or your fingers will do,lifting the trim up a off. BE CAREFUL NOT TO BREAK THE POWER BUTTON WIRES, near the power on button. Then remove the 4 screw holding the back cover on. When you remove these screw the monitor is free, but careful there are 2 set of thin short wires that need to be un plug. You should be able to go for there.
Jan 30, 2011 | Gateway FPD1765 17" Flat Panel LCD Monitor
ImageQuest ImageQuest L17T 17" LCD Monitor: unit does not power up...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | Hyundai ImageQuest L17T 17" LCD Monitor
Developer in my sharp ar-5520s mfp
if you want change developer,pullout toner cartridge open blue screw,remove developer unit ,open 3 screws,remove black cover remove old developer and add new
Apr 30, 2010 | Sharp SF 2020 Copier
Back light does not turn on
The problem can be caused by bad caps in the power supply, bad inverter circuits, bad lamps. You need to open it up and see if there are any bad caps with bulging top first, post back so we can guide you furhter, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 21, 2010 | Hyundai ImageQuest L17T 17" LCD Monitor
HP F1930 Capacitors
This is how I learned to open my f1703hp monitor not sure if f1903 hp is the same...I got my open and going to replace power board waiting for the mail LOL.
http://www.fixya.com/support/t862133-open_f1703
Jan 20, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
My sharp copier AR-5320 just stopped copying and displaying a H
check main power supply socket and plug for blown out fuse,if it doesnt work open the cover on the left hand side to access the power supply board check the fuses if blown replace with the same rating.
Nov 27, 2008 | Sharp AR-5320 Black and White Copier
L17T
If you can open the cover of your monitor try to locate the fuse maybe the fuse is busted replace it.
if the fuse is blown or busted again there is short circuit in your power supply maybe the diode or the power transistor is shorted you need this to bring to the shop for services
Apr 15, 2008 | Hyundai ImageQuest L17T 17" LCD Monitor
Self turn on and off
please change i.f board if problem not solve thet means problem with lcd panel
Mar 01, 2008 | Hyundai ImageQuest L17T 17" LCD Monitor
White startup screen
try this test: put pc into hibernate mode and allow full cycle. if monitor ceases problem, then original problem may be with pc's video output only.
Jun 08, 2007 | Hyundai ImageQuest L17T 17" LCD Monitor
Hyundai ImageQuest L17T 17" LCD Monitor Logo
408 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
