Question about RCA P61940 61" Rear Projection Television
RCA P61940 No picture but sound ok.
I don't see my problem posted after paying. So I'll repost it. Have sound but no pic. Menu comes on and little channel logos appear at bottom of screen when channels are changed. 3 guns are on but not creating images. No smell of component burning. Think it may be rf converter. Can module be found and replaced or should I start troubleshooting board to component level? Thanks.
  • 2 more comments
  • rickm352 Jul 04, 2008
    I've tried input 1 and 2 with rca connectors and again with s-video cord. Just sound, no pic.
    Tried that also.
    PTK195E2T
    Thx all. I figured it out. I've got a weak component. Unplugged the tv for a few hours, turned it back on and it's doing ok now. Happened a couple years back with the sound. If problem starts up again I'll take board out and replace bad part. At least I got a chance to clean the three super, super dusty lens. Bought tv back in 2000. I'm a burg and fire alarm tech. Anyone need some help gimmie a holler, I might be able to help. Haven't worked on systems since 1999, but still know about em and have tons of parts laying around. Too busy to put em on ebay. Take care all.
  • 2,326 Answers
I've anwsered on your premium post.
Try using the audio/video inputs to bypass the RF converter (tuner).
Posted on Jul 04, 2008
  • Jaime Hernandez Jul 04, 2008
    What is the chassis number of your TV?
    I will see if i have the service manual to help you troubleshoot this problem further.
No sound
May have a corrupted EEPROM.
Apr 17, 2014 | RCA P61940 61" Rear Projection Television
Sound
Check that switch on back by external speaker connectors is set to INT. Also check with remote in sound menu that speakers are on.
Comes on blurry cant read any small words at all and can just barley make out the picture.the color appears ok but the picture is blurres
Can you post a pic? It sounds like a convergence issue but need a picture of the screen to be sure if its convergence issue or not.
Jul 24, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on just the green light comes on 3 times
Ur tv DM power supply board have dead leakages capacitors.U have tools,solders and soldering iron?U know how to do soldering.Tries websites like Tvrepairworld.com,Tvrepairkits.com buy a capacitors kit to replaced dead leakage capacitors to the DM power supply board.
Jul 05, 2010 | RCA P61940 61" Rear Projection Television
I was given a rca p61940 rear projection tv. The
It sounds like a convegence problem due to dust on the lenses. Clean the lenses with qtips and alcohol and then use auto convergence in the menu screen.
Mar 08, 2010 | RCA P61940 61" Rear Projection Television
RCA 61" SOUND NO PICTURE HDTV
Contact a Technician to check your HV section of your TV, sometimes the heater on CRT have no supply.
Jun 01, 2009 | RCA P61940 61" Rear Projection Television
Turn tv on, sound comes on but no picture, power light blinks,
The clear bulb located back left side needed to be replaced. Too much heat causes the bulb to burn out. Simple fix. One screw to open door to bulb compartment. Two screws to remove bulb assembly. Thank goodness for extended service warranty which paid for it. This is the second one in three years. At the price of $200 for bulb and $100 for trip and labor, this is not an inexpensive fix. Anyone purchasing a projection tv should get an extended warranty.
Apr 08, 2009 | RCA P61940 61" Rear Projection Television
Stretched screen
Try the menu under setup, find convergence, it realigns the colors,, you are suposed 2 do that periodicly,, or when u move the tv,, should help you ,, ive got that same tv,,
Oct 05, 2008 | RCA P61940 61" Rear Projection Television
RCA P61940 PROJECTION TV
No adjustment will fix this, what has happened is a power supply board for the convergance has failed and needs to be replaced or repaired
Mar 07, 2008 | RCA P61940 61" Rear Projection Television
RCA P61940 61" Rear Projection Television Logo
77 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
