Question about Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity Gas Dryer - White
Access to gas valve
I have a new Samsung Gas dryer that I need to change out the orifice for LP operation. Can anyone tell me how to get to the valve. On my old Kenmore a panel on the bottom just pulled off.
  • claudia ferr Jul 09, 2008
    I have a new Samsung Gas dryer that I need to change out the orifice for LP operation. Anyone tell me how to get to the valve. ?
    I live now in Brasil and here I dont have anyone that can fix for me
    Thank you for help me
    Claudia
    THE MODEL 7.3 Cu fT 9 cycle super capacity gas drier
I have the same problem ... please help me
Posted on Jul 10, 2008
  • 3 Answers
See (how do I remove front panel on samsung dryer for details)
Posted on Oct 22, 2010
How do I change the orifice on my kenmore dryer from natural to a LP orifice?
More and more, you have to change the gas valve AND the orifice due to the liability issue of changing only the orifice and not doing a complete conversion. If, and this might be a big if, a conversion kit is available, you will need the model # of your dryer to order it. The kit will come with a spring and a tension nut for the gas valve and the orifice you need. Instructions will come with the kit. Follow them to the letter. An improperly installed conversion kit, or just changing the orifice, can be very dangerous. LP operates at a higher pressure than the natural gas the dryer was built to use, and an improper conversion presents a significant fire hazard.
Mar 02, 2010 | Kenmore Dryers
I have Natural gas and am moving where it will be hooked up to lP instead. What do I need to convert to LP from Natural Gas
you will need an L.P. conversion kit. the kit contains a small spring, a new brass orifice and a new brass cap that fits on the gas valve. some kits are minus the spring. you will most likely have to remove the burner to put the new orifice in. any appliance repair store will be able to order you the kit. have model and serial number handy. good luck with your move into the country.
Oct 20, 2009 | Kenmore Elite HE4 Electric Dryer
I converted my 40'' Figidaire range to LP a few years back when I did not have access to natural gas. Now I need to convert it back. I do not still have the old parts and there seems to be no ''Natural gas...
I am having almost the same problem. Frigidaire told me to replace all 5 mixing tubes, ~$385, yeah right. They don't have the orifices itemized as an individual part, so no-one carries them, just the LP conversion kit. Another repair/parts guy advised me to drill out the orifices. Some other threads/blogs give the diameter to drill. Basically, since natural gas is 0.5 psi, you need a larger hole than your current propane orifices provide. Please speak up if you find out anything, I will try to do the same. Good luck.
Sep 25, 2009 | Frigidaire PLCF489AC Dual Fuel (Electric...
With the Jenn-Air PRG4810NP (Natural Gas), is there any way this can be converted to LP with a regulator? I'm not sure if I ordered the regulator for the LP range and attached it to the NG model, if this...
Conversion is usually accomplished by flipping the regulator cap around. Nat side is hollow and LP is solid to hold the regulator open. The oven orifices are adjustable and the surface burnres can be either adjustable or have LP replacements.
Eric
Jul 01, 2009 | Jenn-Air PRG4810 (NP) Gas Kitchen Range
Laars Lite 2 Coversion to LP Gas
Hi you will need a gas fitter to do this and set it up
Jun 02, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Changing a gas ge dryer to a propane----convertion package we25x10014 directions show a picture of the control panel with 4 plug ins at the bottom and changing out the last one on the right for the new...
Converting your Natural Gas Dryer to Lp is taking it from a lower BTU gas "Natural" to a higher BTU "LP" value. The orfice on a LP gas valve is smaller because you dont need as much gas to make the same amount of heat. make sure you change the orifice. The little plug goes in the regulator of the gas valve, changing the valve from a low gas pressure Natural to a Higher Pressure LP.
If the kit doesnt look right, did you get the correct one?
Maybe you should call you LP provider they can do the conversion for you.
Jul 10, 2008 | Dryers
Lp conversion
You guys like things that go boom. My advice is to get a certified gas tech. To change the orfice to LP you have to take apart the unit from the front.
Sgt 48
Jan 30, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity Gas Dryer - White Logo
379 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
