Question about Whirlpool CAM2752RQ Coin Operated Commercial Washer
Coin operated machines: slide mechanism is not moving back.
Roper model RAK2751KQ0: coin operated machines: slide mechanism is not moving back, it is stocked inside. I am not able to place the coins
    Problem Solver:
  • 9 Answers
I had a coin washer and dryer.The slider has little fingers(metal)that slide over the coins.If the coin isn't placed and the slider is pushed hard will jam. Mine had a side cover with a lock. Open that and there is a long rod that has to be unscrewed to remove the lock box,then you should is what went wrong.Hope this helps>
Posted on Jan 17, 2009
  • 4 Answers
SPRAY IT WITH W-D 40 AND THEN HIT IT HARD ,IT SHOULD COME BACK IF THE COIN YOU PUT IN IS NOT BENT.
Posted on Nov 11, 2008
Coin operated dryer
replace the belt.
Feb 02, 2014 | Washing Machines
How do i remove the top from a coin operated roper Washer model #rak2751kq0
Hello, donald
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Oct 24, 2011 | Roper RAS8445KQ Top Load Washer
Washing machine wont come on but i check the plugs and the push button are okey . you know any other parts that needs to be replace ? thank you.
If this is a kenmore front loader (boxy type made by frigidaire), the button must be
depressed for several seconds. The second problem with this model is the "coin
mechanism" cam must be in the correct position to operate the machine. If someone
puts in coins two times without starting, it can get out of sequence with the timer.
If you have a key, open coin box and move the metal arm back until the cam advances
to just before the big dip. (with the unit unplugged). The next cycle will allow the
arm to drop and engage the microswitches. If you don't have a key put coins in the
slide mechanism as though you were going to start the machine and
depress button until machine starts, this will reset the cam to the correct position.
Hard to explain but if you look at the coin mechanism, it will become obvious.
If you need a new mechanism it is called the "start mechanism" for front loaders.
Hope this helps.
Apr 16, 2011 | Kenmore 3.1 cu. ft. Coin Operated Extra...
The coin mechanism is hard to push the coin slider, but it works.
Coin mech is held in place with 4 screw heads in key hole slots.
Move the mechinisim UPWARDS about 3mm and wiggle it around to disengage the screws.
The hex bar is only used to stop the mech going upwards.
Sep 12, 2009 | Whirlpool CAM2752RQ Coin Operated...
Coin operated equipment
Go to searspartsdirect.com. Type in the model numbers you provided for each appliance you have mentioned. For the dryer, look under the "Top and Console Parts" heading for item numbers 64 and 66. For the washer, look under the "Meter Case" heading for item numbers 19 and 22. There is a toll free Customer Support number listed that you will need to call for availability of the keys you're looking for. They will request the vendor name (probably listed on the back of the coin box, or on the lock facing) in order to match the keys to your box. They should also be able to provide you with any other guidance and/or answer your questions. I hope this helps you.
If you need further assistance, please let me know.
Jan 13, 2009 | Roper RGX4634KQ Gas Dryer
Roper coin operated washer and dryer with no keys
call A locksmith to drill out the lock then re-key the machines
Dec 19, 2008 | Roper RAK2751WWH Top Load Washer
How to Reset a GE top load Invensys washer timer?
remove slide cover .. move the slide lever back untill it is on #1 or the lowest setting... hope it helps
Oct 31, 2008 | GE Energy Star WCVH6260F Front Load Washer
Machine not starting
These machines are owned by a company or your Landlord you will need to contact them for the repair on the Coin slide
Jan 28, 2008 | Maytag MAT12CS Top Load Washer
Whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Sep 06, 2007 | Washing Machines
Washing Machines Logo
3,320 people viewed this question
Dan Webster
Dan Webster
Sal De
