Electrolux frost free fridge freezer. Warm fridge and ice in the frost free freezer?
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 22, 2010
SOURCE:
How do i manually defrost an LG French door, bottom freezer, refrigerator?
same way but use a fan as well to blow the warm air into the freezer
Apr 24, 2017 | LG Refrigerators
Fridge not cooling
Sometimes the air duct bewteen the fridge and freezer becomes blocked with snowy ice what forms when the freezer has been running without an operative fan - solution switch the unit off with the doors open for 24hrs then clean close it up and switch it on - if it was snow problem will be gone - cheap and easy to give it a try
Feb 21, 2014 | Electrolux Refrigerators
Hi I have an electrolux Rex FI22/10NFB no frost Fridge/freezer Lately its been making ice at the bottom of the freezer and at the top in the fridge what could be the problem?
look along the door seals to ensure they lay flat agaist the body, as an air leak encorages fros/ice build up even in a frost free unit.use a hot cloth to adjust.
Jun 20, 2010 | Refrigerators
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
Mar 07, 2010 | Electrolux Freezers
Freezer froze,ice and frost,freezer door froze, warm in fridge
change thermostat sensors in fridge and freezer easy
Feb 04, 2010 | Refrigerators
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
I have an electrolux Aeg santo fridge freezer. Frost free. There seems to be water leaking from the bottom.
remove back plate inside freezer. there is a drain tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely. check drain tray heater is ok as well
Oct 08, 2008 | Electrolux Refrigerators
Fridge problem
hi
is this a frost free fridge if so then it is possibly not defrostingand has built up to much ice in the evaperator
cheers grantsreps
Sep 29, 2008 | Amana 3.2 cu. ft. Top-Load Washer
I've got an electrolux frost free fridge freezer and it is not freezing. The fridge is cool and cold air is entering the freezer compartment but it is not cold enough to freeze the food. I've removed all...
remove the back panel inside the freezer and check for ice build up on the evaporator pipework. if ice build up, this prevents air flow and hence temp rises.
remove ice carefully with a hair dryer and it should work. if problem comes back, you have a problem with the defrost system and get back to me if you want
Aug 05, 2008 | Electrolux Refrigerators
Fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Jun 23, 2008 | Electrolux ERN2820 Bottom Freezer...
Heating & Cooling Logo
434 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
