Question about Whirlpool Washing Machines
My Whirlpool Duet washer has started to make much more noise in the high speed spin mode, is this normal or is it a service issue?
  • 413 Answers
A loud, roaring noise in high spin speed usually indicates the tub bearing is failing. A large job best left to the professionals.
Posted on Jul 04, 2008
Duet washer making a loud noise on spin cycle, it squeaks on low spin and then when it gets up to high speed, it is really loud. What could this be?
In most cases it is something that is sticking between the drum and the housing. Check inside the boot by the door. If that is not helpful move the drum by hand and listen to see if you can locate the area of the noise.
Dec 30, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not drain or spin, keeps making a rumbling noise, what can I do?
Hello Randall;
My name is Peter. I am a retired field service appliance technician.
I have a Whirlpool Duet clothes washer. They are nice units. The information following is based on my model number GHW9150PW0.
You do not have a drain problem. I am more concerned with the rumbling noise.
1.) On both the front and back end of your drum you have a spring loaded counterweight. It is possible you have a broken spring.
Part #: 8181762 Cost: $24.00
Part #: 8181645 Cost: $17.00
Your should also check out your drive belt. At a high speed it may be slipping.
25395045-azn3vdefrt5enyqdbzatir1e-2-9.jpg Part #: 8181670 Cost: $25.00
The above will effect your independent motor control located inside the washer, located inside your unit.
Feb 01, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ghw9200lw front load washer will not start cycle
Check the door interlock on the washing machine. If it's faulty, the machine won't start its cycle. This page will give you an idea of what interlocks look like.
Door Interlocks
Feb 20, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Loud humming or buzzing only when it spins at high speeds
This noise causes by the drum bearing is getting worse. As soon as the noise is getting far louder and extremely louder then you have to replace the bearing of the outer drum. Normally, the repair cost is as high as buying a good deal new washer.
Oct 14, 2013 | Whirlpool Duet 4.0 cu. ft. Washer
We have a Whirlpool Duet WFW9400SW02 that is making loud noise during the high speed spin cycles. It is only 13 mos old. Whirlpool will not even stand behind the parts. The repair person estimates over...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
After starting the wash cycle, the machine will stop and 06 will flash then F will flash. The washer will not complet the cycle
Hi
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F06 and washer stops spinning , must keep restarting
Hi
Thanks
Rylee
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Oct 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
254 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
