Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
FLSE72GCSA top drum glide
How do I remove the front of the dryer to exchange the drum glide? I removed the top screws and the panel between the washer and the dryer but don't know how to continue, can't see any more screws that are accessible.
Thanks a lot,
Gaby
    Genius:
  • 1,028 Answers
Remove screws holding console on ..2 on bottom rail and 1 in each lower corner of console they are recessed .console will drop slightly and off 1 screw in each corner of front panel be sure to not loose them they go in these spots only..flat heads..recommend removing large front panel between 2 units remove blower housing 2 clips or screws each corner lint screen housing on inside..reach through and remove belt this will make reassembly easier by removing downward pressure on drum ..
Posted on Jul 05, 2008
How to Replace a Dryer Door Switch on a whirlpool
First, make sure the peg on the door that pushes the switch is in place and the two snap pegs that hold the door shut are not broken. If any of these are broken, replace them first and see if that solves your problem. If not, here's how to replace the door switch: Unplug the dryer. Pull out lint screen. Remove two screws revealed underneath. Slide a 1" putty knife between the top and cabinet at the top front corners on each side, jamb it in while tugging the top forward to release the clips, one at a time. Lift top and lean against wall. If it's a gas dryer, remove lower front panel and loosen two 5/16" hex head screws for top front panel. If electric, loosen same screws at bottom of front panel. Remove two 5/16" hex head screws holding front panel from inside near top. Carefully tilt front toward you, holding drum in place. Lift front panel slightly to disengage bottom screws and remove. Gently lower drum until it stops. Unplug two (sometimes three) wires to door switch on right side. Now the front panel is completely free. Remove two Phillips head screws holding door switch onto front panel. Reassembly is the reverse of disassembly. Make sure wiring to door switch is secured to cabinet so they don't drag on the drum, and are not pinched. Be careful realigning the drum into the door opening so felt seal is inside the front glide ring on the drum. After the front panel is in place, gently hand turn the drum to make sure it is turning properly and the belt in still hooked to the idler and motor pulleys. If the drum falls off the rear rollers, or the belt comes loose, you will have to correct it before putting the front panel back on, as you cannot reach them otherwise. Taking pictures during disassembly will help get it back together properly. It really is not as hard as it seems, you may even be able to replace the switch without removing the front panel. Also, if you have a three wire switch, write down where they go or snap a picture. If it's a two wire switch, it doesn't matter, it will work the same either way. Good luck.
Feb 18, 2014 | Whirlpool 358409 Washer/Dryer Screw &...
Tip
417.91702000 Broken dryer belt and felt replacement
To get inside the dryer portion you start by removong the top making a note of where the screws mount makes it easier to put back right later but is no big deal. After removing the top you remove the splashplate and then the controlpanel. The panel has quick connects so the wiring will be no problem. Once the control panel has been removed get the front panel off ad remove the drum.
IThese dryers comewith 2 different styles of glides. The drum mounted version and the front panel mounted versions. The glide kit comes with glue also. I have a page which features videos and more on frigidaire dryers. HERE
Laundry center service manual
on Dec 11, 2010 | Washing Machines
Our dryer makes noise (like metal to metal contact
you will need to replace the dryer drum glides on the drum front panel after front panel removal by removing the toe kick panel screws and removing panel this should let you do this w/o removing top cover
Jan 19, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Squeeks loudly when in use
it is either the front felt/glide or the rear bearing. take the two or three screws off the top panel in the back and remove the top. there will be a couple screws going in the front panel. remove. there is a yellow clip in the center holding the drum in place remove clip as well. front panel will tip ahead. you will be able to see the felt/fglide kit now. most likely the white glides are worn off. if not disconnect wires and remove panel fully. go under the drum and remove belf from motor pulley. the drum will remove by pulling up on the back of the drum. once it comes up pull out the front, and look at the bearing assy.good luck
Nov 28, 2009 | Frigidaire FEQ1442ES Electric Dryer
I need to replace the drum seal due to brown stains on clothes.
When the front door glide system on the fex series dryers wears out the drum isn't held in place properly, there is enough of a gap between the bottom of the drum and the front panel for clothing to get in. As the drum rolls and the item moves to the top it becomes pinched as the gap closes leaving stains and sometimes damaged clothing.
If this is what you are talking about, Make sure it is unplugged then remove the slanted panel above the washer lid. remove the control panel (4 screws) it can be unplugged (2 plugs on left side) and laid aside (rubber line can be removed and slid out of plastic clamp.
when the control panel is removed you will find two screws holding the bottom of the front panel, these have to be removed.
there are 4 screws along the upper edge of the front panel that have to come out and then the front will come off.
Reassembly is difficult with this machine (I remove the dryer door if I'm working alone) so try to do the job when you have help.
Good Luck
Quentin
Jul 11, 2009 | Frigidaire FEX831CS Top Load Stacked...
How to remove the drum from the front and replace the drum support cup kit.
Release the top by pushing in the clips with a putty knife at the front right and front left of the dryer. Once you release the top you can remove it by disonnecting the ground wire at the rear of the top panel. Remove screws that secure the front panel to the dryer. Once all the screws are removed give the front panel a tug to pop it from the clips. Unhook the wiring harness and remove the front panel. By now you can see the drum. Remove the belt from the motor and idler wheel pulley. Yoy will need to get to the rear of the dryer and remove a grill (lower left corner).to gain access to the pulleys. Once the belt is removed, grasp the drum at the rear and give it a quick **** upward to release the drum from the rear bearing. The drum can now be removed through the front.
If you are replacing the rear bearing, consider also replacing the front plastic glides/slide that are located at the top of the door.
May 23, 2009 | Frigidaire FDE647RF Dryer
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
My Maytag dryer Model DE308 is very noisy. sounds like something is catching or grinding. can I fix this?
most common cause is the failure, or wear of the rollers at the rear,
the drive belt places a lot of torque on the drum, and it has rollers to support this force, in addition to nylon guides as the front has
good roller
worn roller
most dryers access from the front, the front panel and door come off,
here are generic removal instructions
with dryer unplugged examine lower front panel.
If there are two screws at lower corners
  • remove screws
  • swing front panel up from bottom
  • unhook top clips
  • undo door switch wires
  • set panel and door aside
If there are no screws
  • remove llint screeen from top
  • remove 2 screws from under lint screen
    push spring clips at front top corners
  • tilt top up
  • remove 1 screw each side 1/3 way from top of dryer
  • undoor door switch wires
Common to both types
  • reach under drum to belt tensioner, pull tensioner to end of spring travel
  • unhook belt from motor and tensioner
  • examine rollers felts nylon guides
replace rollers in pairs if worn
replace nylon glides if worn
replace felts if worn, the back one may wear before the front one,
if the dryer is the open drum type,
Oct 17, 2008 | Dryers
Kenmore Laundry Center #417.90802990
unplug it drop the panel between easher dryer remove the metal panel behind it remove 2 screws each side controls panel reomve control panel unplug the switch going to dryer door let panel hang down remove 2 screws bottom door panel one each side remove 4 screws on the top front panel with door will fall in your hands oyt seals on it let dry
Feb 28, 2008 | Dryers
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
280 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
