Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears Wireless keypad will close door but will not open
I have a Sears wireless wall mounted keypad model 139.53684. When the door is open and key in the code, the door will close. When the door is closed and you key in the code, the door will not open. Wired wall mount and units in car can open and close door. I have replaced battery and changed codes, but all the wireless wall unit will do is close the door.
  • 2 more comments
  • luv2getpar Jul 20, 2008
    I have the exact same problem and really appreciate any help I can get to fix this.
  • Anonymous Sep 16, 2008
    I have the exact same problem.
  • Anonymous Jan 01, 2009
    The same problem occurs for me every winter. In the warmer weather the opener works beautifully. I have no solution, however.
  • charodon Jan 15, 2009
    We are having the same problem right now. The temperature just shot down to around zero when it happened. Swapping out the battery does nothing.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
If you are sure the battery is good than it sound like the keypad is bad and needs to be replaced. With a 6+ year old operator I would suggest a wired keyless entry (Donino GD-1) so if the operator has to be replaced you can use the same keyless entry.
Posted on Jan 02, 2009
I have a Sears Craftsman opener that will not open with the wireless keypad but it will close with it, and all other remotes and wall mount work fine.
First thing make sure the battery in the keypad is good. If this is not the case then your keypad is losing signal strength and will need to be replaced.
Mar 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
Car remotes will open door but not close it. Other wireless remotes will not do either. Keypad will not do either. Wall mount will open and close. This problem just started. Also had problems with the...
It sounds like you have a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have a bad sensor.
Feb 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster Security wall mount keypad won't open the garage door. It will make it close but won't open it back up. I replaced the battery but it didn't change anything. The keypad will blink for...
You might try programming it but I think it is bad.
To program locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
Aug 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not open close with remote
Press and hold for 3 seconds the button on the wall control with the lock icon.
Aug 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Red light/stuck GDO Sears 139.53600
is it locked. does door lift manually. are springs/cables ok?
Jan 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
210 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
