Question about Hitachi 53UDX10B 53" Rear Projection Television
HCL552 - Samsung Red Convergence
I have adjusted as far as I can on screen with remote but still have red, bowed lines at the top...is there a manual adjustment that I can do if I open up the back of the set or do I need parts replaced?
Thanks
  • 927 Answers
Good Day, raysdad;
You need parts replaced. The parts are the STK' in the Convergence Circuit.. It's best that you have a Factory Authorized Service Center come out and give you a written estimate B4 repair. Good Luck, big IRISH. PS: about $550.00.
Posted on Sep 02, 2008
Picture is distorted. Red band from top. Is this a repair I can do myself?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Apr 28, 2010 | Samsung HCN4226W 42" Rear Projection...
Conversion-----the red lines are distorted so badly they won't move at all. I've managed to line the other lines up. The top left quadrant has drooped so badly that they will not adjust back. The bottom...
  • Screen looks 3D
Feb 11, 2010 | JVC AV-56WP74 56" Rear Projection...
Red, green, and blue lines at bottom of screen, mirror looking effect, also looks like 3D. Got at a garage sale so no manual.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 03, 2010 | Hitachi 43F300 43" Rear Projection...
Blue convergence bows when watching tv, hdtv looks great
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
Sep 14, 2009 | RCA HD52W58 52" TV
Sony kp46wt510 red only convergence bowed on top and bottom
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Nov 19, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
1991 hitachi 60sx1k rear projection, lines are bowed at top and botom
  • Screen looks 3D
Oct 23, 2008 | Hitachi 50DX20B 50" Rear Projection...
Convergence
  • Screen looks 3D
Oct 09, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Bowed colored lines on top of screen
  • Screen looks 3D
Sep 16, 2008 | Toshiba TP50G90 50" Rear Projection...
Samsung 65 rear projection
  • Screen looks 3D
Aug 04, 2008 | Samsung HCN653W 65" Rear Projection...
Red bow on top and bottom of 61dx01b
  • Screen looks 3D
May 21, 2008 | Samsung PCL5415RB 54" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
