I have sound, but no picture
The TV worked fine, then this problem happened intermittently, and now it happens all the time. What happens is when I turn on the the TV, I see the picture for about 2 seconds, then it goes blank. It was working fine yesterday, then I turned it off for a couple hours, and came back to the problem I'm having. I've tried unplugging the TV for long periods of time and it still doesn't work. I've had this TV for only 4 months.
  • Josh Tucker Jul 04, 2008
    The TV is a Westinghouse Widescreen HDTV Model No.: SK-32H240S.
  • 8 Answers
SOURCE: Samsung HLN5065W Light Engine problem or not?
Look at my ether post on cleaning out the DMD bord I thank this will fix your problem.
Posted on Jan 02, 2008
maklean
  • 1665 Answers
SOURCE: Bought a Hitachi L37V01U a
It may be a power supply fault.
Posted on May 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Posted on Jun 15, 2008
RFICKES
  • 51 Answers
SOURCE: Sony KDS-55A2020 picture goes blank then returns
This sounds like the ballast for the lamp is going. The ballast sparks the lamp, and if it starts to go, there's not enough current to keep the lamp sparked. Thus it starts to fail: it's the same principle as a fluorescent lamp fixture. Ballasts are available at any service depot, but they're fairly expensive, and perhaps prohibitively so; you may want to look at replacing the monitor itself.
Posted on Jan 07, 2009
SOURCE: mitsubishi WD-62827---PICTURE TURNS GREEN
I had the same problem. I deducted that if my TV worked fine for an hour or so and then the colors became bad (green, people's faces purple...), it must be a overheating problem. Simple logic, right? So, I picked up a few tools and a small vaccum and went to work.
I went first for the main source of heat: The lamp. Just a few screws, and I removed it. The lamp cage has a fine screen to prevent the dust to cover the lamp. Mine was covered with dust! And the fan behind the lamp was also covered with dust! Bingo!!! That's my problem! I cleaned everything and vaccumed all the air vents on the the back of the TV. I put the lamp back and checked that the fan was working. The TV works like new since!
Before you are out of a TV for days and spend an arm and a leg for a "Technician" to fix it (replacing expensive parts that didn't need to be replaced in the first place), try what I described above first. It's very simple and it takes only 15 minutes.
Since my TV is 2 1/2 years old, I purchased a replacement lamp. I know that one of these days it will burn out. I'll be ready and my TV will be working again in 15 minutes!
Since my problem was solved, I didn't go to the next step. There must be one or two other cooling fans inside the TV, but they must be working...
Good luck,
alecoz@roadrunner.com
Posted on Jan 25, 2009
Testimonial: "YES IT IS A HEAT ISSUE(IF YOU HAVING GREEN SCREEN ISSUES LEAVE THE BACK COVER OFF AND PUT A SMALL FAN BLOWING IN THE LIGHTBULB AREA.PROBLEM SOLVED"
Sharp LC 26sh20u picture problem
There are several capacitors on the main board and the power supply that can go bad with age. There are repair kits available that address this problem. Go to www.shopjimmy.com to see what's available. TV Parts DLP TV Lamps TV Repair ShopJimmy
Jan 14, 2014 | Televison & Video
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
Sharp LC-46SB54U Keeps losing picture intermittantly
i believe your tv is getting overheated, possibly from dust getting onto the electronic components inside. or the inverter board for the lcd panel inside is going bad, alot of times it is the capacitors on the lcd inverter board going bad.
Jun 12, 2009 | Sharp LC46SB54U 46 in. LCD TV
I have a Samsung HLN437WX DLPTV. The problem that
no if the lamp works fine for hours , could be a signal problem check signal connection and wiring
May 04, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Electro Med Services...
