Question about Minolta EP4000/5000 CS/PRO Copier
Konica/minolta ep4000 toner not even across page; has partial voids down page. cleaned everything. did half-test and image is bad at drum. what needs to be done next and in what order thank you Bob
    Sniper:
  • 57 Answers
You have plenty things to check sorry to say. What is the condition of drum and starter? What about the charge assembly? Is the grid still in good condition?
Posted on Aug 03, 2008
My bizhub c451 is still printing only cyan and black after we change toner catridge, what could be the problem please
The problem could be the laser that scans the image or the detectors that see the colors. It could also be a problem with the power supply or the main board. This is not going to be cheap. If you want to continue, you should download the service manual.
http://www.printcopy.info/?mod=docs&brand=Konica-Minolta&gID=15037
Jul 20, 2015 | Konica Minolta Bizhub C451...
KONICA MINOLTA BIZHUB163 MAINTENANCE CALL M2
Replace the developer and drum make sure counters are cleared for the drum and developer. because machine works off the counters if the counters are clear it assume new drum and developer are installed and set voltage to the drum and developer based on it, if in fact he drum is not new or developer then image problems and code can appear
try web site below as start to get parts, recommend Konica Minolta tech do it.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 07, 2012 | Minolta EP4000/5000 CS/PRO Copier
My photocopy machine minolta ep4000 its up and bottom side of the page are coming black
When was the last time you had a Konica Minolta Tech come out and give it a cleaning and replace parts such as developer, Drum, corona wire xfer and sep wires, cleaning blade. Botton fuser roller mite need to be replaced. A Minolta legacy machine, try the web site below to get a start on the above parts Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Oct 20, 2011 | Minolta EP4000/5000 CS/PRO Copier
Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
May 10, 2010 | Konica Minolta Office Equipment & Supplies
Yellow deposit
Remove the Yellow Drum unit, Check the drum for any toner. The drums should be clean and I believe a Green color. If you see any toner on the yellow unit replace the unit. Some models have a charge cleaner built into the image units, if that is the case with yours you will see a light blue knob on the front of the unit. Pull this knob in and out about 5 times to clean the units charger this may correct the problem without replacing the yellow image unit.
Mar 09, 2010 | Konica Minolta Magicolor 5670EN Color...
My 2300W prints a second image
Yes, it sounds like a fuser problem, as the oil and coating wear off of the fuser rollers they transfer to the page as you describe. The only way to tell is to stop the machine in a print cycle before the fuser to determine if the problem is before or after the fuser.
Aug 31, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Laser printer
I developed a color print that has all 4 principal pure toner colors in vertical and horizontal bars that are at least 2" wide.  If perhaps you are having a toner problem only one of the colors will be affected.  If all colors are affected there are two possible issues.  The drum, which I think is actually a belt, and the other the fuser assembly.
The fuser is a heater and pressure roller system that presses and melts toner onto a page.   The drum is an imaging device that picks up toner where images should be and transfers toner onto a piece of paper.  Any toner not transfered from the drum / belt is destined for a waste toner hopper.  If the belt is not being cleaned properly or has an image or flaw artifact that cannot be cleaned / erased you always get that printed on a page.
Aug 04, 2008 | Konica Minolta magicolor 2400 Laser...
62 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
