Question about Technics Audio Players & Recorders
Over Load light turns on and then we have no sound
It keeps locking (over load light turns on and there is no more volume) I turned the system off and then back on and we have sound. Then after a couple of seconds the light again and no sound. I do not have the remote control
TECHNICS AV CONTROL STEREO RECEIVER SA G9013
  • 682 Answers
Please disconnect each speaker one by one and test it until you find the bad one-start with cable change and then the speaker itself.
Posted on Jul 04, 2008
2487 LG front load washer
sounds like a door lock issue , i would replace the door lock if you are not getting any error codes.
door lock error would be a DL
Feb 17, 2013 | LG WM2455 Front Load Washer
When i turn my volume up to a certain point the power light on my amp will blink off and on and the subs will cut off...what could be some possible solutions? is the amp not suppose to be tuned up? it...
Sounds like you are showing too low of an impedance load to the amp. The E1200 is only stable as low as 2 ohms. If your subs are wired to show lower than a 2 ohm load then the amp will go into protection mode as the volume or gains are turned up
Dec 23, 2010 | Jl Audio E1200 Car Audio Amplifier
How do I get our whirlpool duet washer control lock light off ?
Hold the end of signal volume button down for 3 seconds to turn the control lock on and off.
If that does not work then: a) unplug the washer or b) put the washer into diagnostic mode using the instructions from this thread http://applianceguru.com/forum2/1540.html.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
After a load it makes a sound and as if the door
your lock could be bad, but when it unlocks it buzzes as if already unlocked? Is the door actully unlocked during the cycle but display reports locked? this would be a bad switch within the lock asm
Jul 14, 2009 | GE Energy Star WCVH6260F Front Load Washer
My volume touch pad does not work correctly with my volume icon on my desktop. By this I mean: The blue lights that turn off and on when you turn down or up the volume do not work correctly. I will have it...
yes mine did that too, i believe that it has something to do with messing with the volume before the drivers load, that means that if you mess with the volume in a different operating system, during boot, at the welcome screen, or during shutdown....you miss align the pad lights with the OS volume level, so next time you shut down drop your vol. in the software to ZERO, then on startup get the touch pad to ZERO, (not mute) before windows fully loads and you login
May 11, 2009 | Acer Aspire 6920 Notebook PC
Poor sound/ Unable to play anything load without distortion.
i can tell you right now base on the vehicle you have a bad system hook wosrt if you are using factory head unit
Mar 25, 2009 | Kenwood KAC-8151D Car Audio Amplifier
ONKYO TX-DS939 (sound and heat/fan issues)
This sounds like the amp is seeing too small an impedence load. In other words, the amp is expecting to see an 8ohm load and is being presented a 4 or 2 ohm load. This will force the amp to work really hard and generate excessive heat. Does the amp generate sound at all? ever? If not, then you probable have a situation with high frequency oscuillations that you can not hear. This means that the amp is sending out a lot of power to the speakers that the crossovers are shunting to ground. Without seeing the output of the amp with a scope, I can not confirm this. This is not a problem that will be solved remotely. Bring the unit to a shop and request that the output be examined using a scope to check the waveforms. I suspect that a bad feedback look internally is causing the generation of the high frequency signals.
Keep us posted.
Dan
Oct 29, 2008 | Onkyo TX-DS939 Receiver
Volume lock code problem
if you load up your Ipod into Itunes and restore back to factory settings you can adjust that way.
Aug 01, 2008 | Apple iPod nano
Locks up at update database screen; won't load firmware; load main image failed. Have tried all kinds of solutions suggested by many, nothing works correctly on my player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 29, 2008 | Audio Players & Recorders
Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Nov 19, 2007 | Whirlpool GHW9200L Front Load Washer
236 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
