Question about Brother GX-6750 Typewriter
Margins I know how to release the margins, but how do you reset them to a different setting? Chuck
  • Edna Mccall Aug 13, 2008
    II have the same problem I know how to release the margins but how do I reset them. Please advise Micci33
  • 328 Answers
After you get past the current setting move to the new desired position and then hold the alt key while pressing the 7 key.
Posted on Aug 18, 2008
How to reset the margins on Brother EM-530
On most electronic typewriters you change the margins by pressing the code button and holding down the press r margin or l margin on the key board. You want the carrier to be where you want the margin set. To set margins beyond the right or left margin move the carrier to the margin and press margin release to go past the margin. Then press code left or right margin.
Jun 30, 2014 | Brother EM-530 Typewriter
Reset margins
Go to the R. margin, press but don't hold the mar rel key, space to desired location, press R MAR, DONE.
DickyO
May 27, 2010 | Nakajima AE-710 Typewriter
How do I type to the end
To reset the margins you need to first release the margins. Once you have released the margins you will be able to set the left and right hand margins.
Thanks,
Pat
May 12, 2010 | Brother GX-6750 Typewriter
How do I do a left or right margin release??
You need to release both the margins before being able to set them again or to get rid of them all together.
To release the margins, you need to press the "alt" button and the number 3.
This should release both the left and the right margins, so if you only wanted 1 reset, you will need to set the one you wanted to keep over again.
Thanks,
Pat
Apr 09, 2010 | Brother SX-4000 Typewriter
Changing margins
To change or reset margins, the keys involved are the ALT key to the left of the spacebar, the #keys 3,4, & 5.
The ALT & '3' keys are used to bypass the set margins.
To bypass the left margin, move the carrier to the left margin. Press the ALT & '3' keys at the same time. Release them then backspace the carrier to the point the new margin is wanted. Press the ALT and '4' keys at the same time to set the new left margin.
To bypass the right margin, move the carrier to the right margin. Press the ALT & '3' keys at the same time. Release them and spacebar to the point where the new right margin is wanted. Press the ALT & '5' keys to set the new right margin.
The main thing to remember is to move the carrier to the point where the new margin is needed. ALT + 3 bypasses old margins, ALT + 4 sets the left margin, & ALT + 5 sets the right margin.
Feb 24, 2010 | Brother SX-4000 Typewriter
Margins will not hold, have to keep resetting them.
Auto margins are permanently stored in the Swintec 8014S. If you set new margins within those margins, they should hold. If you set them outside of the auto margins you will have to use the MAR REL key to release the auto margins, and then set the new margins. All margins are set by pressing the Left or Right Margin Set keys.
These settings are stored in a memory circuit that is powered by a battery that is automatically charged when the typewriter power is on. If you still have trouble with the margins releasing after you turn off the machine, you can try one of the following:
(1) Keep your typewriter on for a couple of hours so the battery can recharge and then save your margin settings
(2) Replace the battery which may have died after all these years. You would need to bring your Swintec to a local dealer for the part and replacement service.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Apr 06, 2009 | Swintec Office Equipment & Supplies
Reset margins
Above the number keys are words in green or blue the margin release, L. mar. and R. mar. are there return to the L. margin, press the alt key with the mar. rel. release them, backspace to the location for the L. mzr press alt and L. margin key, R. margin works the same way.
DickyO
Mar 18, 2009 | Brother SX-4000 Typewriter
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
Cant find margin release
Generally, the way the margins work is, wherever the printhead is positioned, when you hit the right or left margin set, is where the margin is set. To reset the margin you must move the printhead to where you want the margin set, and hit the appropriate mar. set button. to move the printhead past where the margin is set, you must hit the "mar rel" button, and then backspace or space to where you want he printhead positioned. On machines without a "mar rel" button, you just use the "backspace" or "spacebar" to move past the margin. You can't release the margins permenantly, you can only move them, or move past them using the above mentioned processes.
Oct 05, 2008 | Office Equipment & Supplies
Brother GX-6750 Typewriter Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
