Question about Teac DUAL CASSETTE A/R 110/220 Single Dual Cassette Deck
TEAC CX-370 Cassete Deck
Hi:
I have an old TEAC CX-370. It powers up, but when I push play, FF, or rewind, nothing happens. If I remove the cassete an push play, one of the spindles turns. Can I repair this myself? What do you recommend?
Thanks!
Jon
  • Teac Master
  • 5,259 Answers
Could be a worn out belt? The cassette loads it the drive down too much. Hence why it turns with no tape.
Posted on Jan 21, 2009
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
Teac troubleshooting
Find the phone number for Richer Sounds, they are helpful and deal with Teac.
Jul 22, 2014 | Teac A420 Cassette Deck
Teac HDR2500T Fast Forward/Rewind problem: It
easy, download the software update from the teac website- had the same problem myself
Jan 10, 2010 | Televison & Video
Cassete deck will not work, I put a tape in deck 2 and hit the record button and all it did is started to make a clicking noise. Next I tried to take tape out and the door would not open. I forcefully...
I have a sony twin cassete deck and the same thing happened to mine , it turned out to be the rubber belt inside was broken so i just bought a pack of assorted belts for $7.97 and replaced both belts .
Jun 05, 2009 | Aiwa NSX-A767 Shelf System
How do I set the clock on my aiwa cx-N990 desktop stereo?
-power on the stereo
-push the clock button
-press pause on the cassette deck - the hour should be blinking
-press fastfoward/rewind to adjust it up and down
-push pause again to move to minutes
-push ff/rewind to adjust minutes
-push pause one last time
Mar 07, 2009 | Audio Players & Recorders
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
DHR- 1000
Recently repaired one of these with what appeared to be a power supply problem; found several defective capacitors on the drive board. The symptoms were similar to what you are seeing.
Aug 20, 2007 | Sony DHR-1000 DVHS VCR
Sony DCR TRV70 - Tapes won't play
the head may be dirty, clean it by using a cleaning cassete, maybe its playing but can not produce a clear picture, not able to produce a clear picture would automatically change the display to blue.
May 19, 2007 | Sony Handycam DCR-TRV70 Mini DV Digital...
351 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
