Question about Maytag Dryers
LD 8410 MAYTAG DRYER .... DRUM TURNS .... NO HEAT......HOW DO I TAKE OFF THE BACK
  • 481 Answers
  • before taking it apart, if it is an electric dryer, then check the circuit breaker in the house. sometimes only one side of the dual breaker will trip leaving you with a running dryer with no heat.
  • maytag dryers are accessed from the front. look for 2 screws on the front panel near or at the bottom. these hold the front panel on.
  • let me know if you need more help
Posted on Jul 04, 2008
Adc dryer yes drum turns exhaust clear lots of make up air no heat
I'm assuming this is the commercial model?
first thing unplug for 5 minutes plug back in to see if it resets.
here is the parts break down if you need parts.
thermometer?
https://www.partswarehouse.com/Maytag-MLG32PDBWW-Gas-Dryer-s/105269.htm
Jan 05, 2018 | Dryers
My dryer does not have any heat.
Is this electric or gas or what?
Sep 07, 2016 | Maytag Dryers
MAytag 2300 aww does not heat
If this is a gas dryer it may be the ignitor has failed. There should be a panel you can remove to inspect the burner compartment. Turn on the dryer and look for an orange glow if you don't see any glow the ignitor is probably faulty and should be replaced. If it is an electric dryer it may be a bad heating element. Hope this helps.
Jan 03, 2014 | Maytag Dryers
Drum turns on heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 09, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Drum still turns but no heat where do i find the heater
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 12, 2010 | Maytag PYE2300AY Electric Dryer
On mine, I took off the back and it is inside a metal channel. Some are just out where you can see them when you take back off. Best of luck
Mar 21, 2010 | Maytag PYE2300AY Electric Dryer
Model PYE2300 AYW the dryer turns on and provides heat but the drum does not spin
your belt has come off the drum or has broken. Take the model and serial number to parts house for replacement. The belt should be accessed through the back of the dryer. Good Luck on your repair. Make sure to disconnect electricty before removal of back.
Dave
Aug 05, 2009 | Maytag PYE2300AY Electric Dryer
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Dryers Logo
134 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
