Question about HP Photosmart C3150 Printer
HP C3150 Printer Continuing Paper Jam Errors
When I try to print print, the paper is pulled in about 4 inches, then stops, one loud click, then the paper moves in just slightly and then another loud click and it stops. After it stops, the printer makes a longer and then a shorter quiet sound (kinda like the sound it makes when scanning). Then the "Check Paper" light flashes, and I get the "Paper Jam" pop-up. When I press the "Cancel" button, this keeps repeating with the paper attempting to be pulled in further, and the paper does move slightly, but is still jammed in the middle of the path. The paper is a gets a little crumpled during this process too.
I have tried to clean the internal part of the printer by opening the front and rear access panels, unplugged the printer, etc. but nothing is working.
Please help.
Miffed in Mansfield
  • Anonymous Dec 20, 2008
    I have the same problem. This printer is more trouble than it it worth. It is piece of junk.
  • HP Master
  • 2,794 Answers
Sometime the ink jet mechnism is out of time or it gets stuck in the lock position. You might want to see if it looks like there crooked in the trays at the end of the printer.
Posted on Jul 04, 2008
Paper jam
Have you tryed replacing replacing the pick up rollers? Also make sure that the paper guides are snug against the paper.
Jul 06, 2013 | Brother MFC-7820N Printer
Printer says Paper Jam but it is not
  1. Remove the paper from the paper tray.
  2. Press the Power button and then wait for the jam to clear.
    • If the paper jam cleared, try the print job again.
    • If the paper jam is not resolved, continue.
  3. Remove the rear access door. Press the handle to the right, and then pull out the door.
  4. Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
  5. Replace the rear access door.
  6. If the paper jam cannot be removed from the back of the printer, raise the product cover, carefully remove the jam from the front of the product, and then lower the cover.
  7. Re-load the paper in the In tray. Fanning the paper makes sure that the pages are not stuck together.
  8. Press the Power button ( ) to turn on the product.
  9. Open the document in the application in which it was created.
  10. Click File, Print, Properties, Printing Preferences click Paper/Quality tab.
  11. Verify that the type of paper specified in the Type is text box matches the type of paper being used. A paper jam might result if photo paper is specified in the Printer Properties dialog box, but plain paper is loaded in the printer.
  12. Click OK to try job again.
Sep 22, 2009 | HP Deskjet D2360 InkJet Printer
Paper jam
I was able to access the back door of the printer and removed the paper from the back.
Dec 02, 2008 | HP Photosmart C3150 Printer
Printer problem
Uninstall your current C1350 drivers (you should reboot after the uninstall). Then visit HP and download the latest drivers for your operating system. Try printing.
Nov 04, 2008 | HP Photosmart C3150 Printer
Paper Jam
With printer unplugged, open lid and pull paper out by hand. Depending on where paper is jammed, you may have to lift out toner cartridge first. Be careful when pulling out paper, especially if paper is crumpled up. Sometimes it is easier to pull paper from back of printer as if it were continuing to print, and others it is easier to pull reverse from the front.
May 17, 2008 | HP LaserJet 4L Printer
Hp psc 2210 printer jam
your printer need to be opened and check for any lever is struck or dislodge, it will be better if you send it for servicing
May 01, 2008 | HP PSC 2210 All-In-One InkJet Printer
Paper Jam & Flashing Light
take everything out and look at all the rollers and printer path and look in the back of the printer
Jan 15, 2008 | HP LaserJet 1320 Printer
Printer will not print 4X6" pictures.
Loading index cards, post cards, and 4 x 6-inch photo paper Remove the paper output tray and all paper from the paper supply tray. Slide a stack of cards into the paper supply tray until they stop. Make sure the print side is face down. Adjust the paper-width guide against the cards, and then slide the paper-length guide in until it stops. Make sure the cards fit within the tray (do not overload it), and then reinstall the paper output tray. Figure 3: Loading a stack of cards 80455c3.jpg
Nov 10, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP Photosmart C3150 Printer Logo
252 people viewed this question
Ben Johnson
