Question about GE Refrigerators
Water despenser does not work - GE Refrigerators
OK EVERYONE...
HERE IS YOUR SOLUTION FOR WATER AND ICE DISPENSERS ON GE UNITS NOT WORKING BECAUSE OF FROZEN LINES.
GET A HAIR DRYER...
USE THE HAIRDRYER TO WARM UP THE LINE THAT STARTS AT THE BOTTOM LEFT HAND SIDE OF THE FREEZER DOOR.
WARM UP EVERYTHING ALL THE WAY UP THE SIDE UP TO THE WATER DISPENSER.
WARM UP THE TUBE WHERE THE WATER COMES OUT.
(BE CAREFUL NOT TO PUSH THE WATER DISPENSER SWITCH...COMMON SENSE)
KEEP WARMING UP THE DOOR AND TESTING THE SWITCH UNTIL YOU GET WATER...
IT TOOK ME ABOUT 20 MINUTES...IT MAY TAKE LONGER DEPENDING ON HOW BAD THE LINE IS FROZEN.
I HOPE THIS HELPS...
Posted on Feb 25, 2009
  • 481 Answers
  • first check the water line behind the pans in the refrigerator. the water may be frozen in these lines. water is held in the back of the refrigerator to chill it before it goes to the dispenser.
  • or the water valve behind the machine may be bad
  • the dispenser switch in the door may be bad
  • let me know if you need more help
Posted on Jul 04, 2008
Water dispenser does not work. However, the ice maker does work so there is water availabe. Could this be a pump problem, if yes how do I replace.
It is not your pump, because despenser and ice maker both get water from the same pump.
Water despenser is activated by a small plunger when you press your water glass against it
to release the water. This is your problem, bad plunger.
Feb 03, 2011 | Amana ARS266ZBS Side by Side Refrigerator
I am having problems with the ice maker. The water freezes but it will not roll over. I have to pull the ice off of the tray the ice is made.
check to see if water despenser is despensing water slow that normal. replace water filter . it will work ok
hope it can help u
Jan 12, 2011 | Electrolux E23CS75DSS Stainless Steel
No water flow to ice maker or water despenser...water lines are clear the filter is clear..could problem be water inlet valve ( dual valve controls water flow to ice maker and water despenser.
Its odd that both parts of the valve went bad at the same time. Personally sounds as if your water filter is clogged up and needs to be changed. I would do that first, before trying to change the water valve itself.
Dec 08, 2010 | Whirlpool Refrigerators
Water just keeps pouring out of the top of the ice despenser
I would say your water valve in the freezer is locked in the open postion or has broken.
Jun 07, 2009 | GE GSH22SGRSS Side by Side Refrigerator
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Ice despenser not working
use a hair dryer, it will thaw the ice and not damage the plastic
Apr 26, 2008 | Kenmore 50522 / 50524 Side by Side...
Fabric softener does not despense
clean the water filter in the back of washer. Look up inside of water inlets you will see water filters in cold and hot inlets. Pull stright out with a pair of pires and fush with water.
Dec 10, 2007 | Samsung WF337AA Front Load Washer
Refrigerators Logo
287 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
