Question about Edimax BR-6104KP Router (BR6104KP)
Set up for locationfree player
What is the password of edimax 6102
    Novelist:
  • 143 Answers
I assume that you are asking for the password to log into the router's page. if so, the default password is "1234" and the default username is "admin"
hope this'll help you
ciao
Posted on Jul 05, 2008
How set password
You need to download the manual for this Middle East version of the access point/ wireless extender. Page 4 covers resetting the router so a new password can be put in.
http://us.edimax.com/edimax/mw/cufiles/files/download/manual/transfer/Wireless/EW-7206APg/EW-7206APg_PDg-Manual-EN.zip
If you press and hold the reset button for more than 4 seconds, the Access Point will reset to the factory defaults (Warning: Your settings will be deleted and replaced with the factory default settings).
Apr 28, 2014 | Edimax EW-7206APg (EW7206APG) 802.11b/g...
Can't find password for my router. tried: user name - admin , password - admin user name - admin , p...
Reset the device to default settings, then reconfigure the device's SSID and Security Key. Try here for support, you didn't post the Edimax model number: http://us.edimax.com/ You can use this procedure to reset: http://compnetworking.about.com/b/2009/03/11/the-30-30-30-hard-reset-rule-for-routers.htm
May 17, 2013 | Edimax Computers & Internet
Cannot connect my wifi, edimax br-6225n to my Cellphone medias n-04c
Here is the manual for the router and how to set up the router t the Internet.
http://us.edimax.com/edimax/mw/cufiles/files/download/manual/transfer/Wireless/BR-6226n/BR-6225N_Manual.zip
The Cellphone is capable of using 802.11b/g/n. So it should be capable of being set-up on Wi-Fi to use the router, as long as you set up the correct SSIS and password for the router.
Here is the manual https://www.nttdocomo.co.jp/english/binary/pdf/support/trouble/manual/download/N-04C_E_All.pdf
Mar 05, 2013 | Edimax Br-6225n 150mbps Wireless ...
Edimax br-6424n password
If you do not know the password, you need to reset it to the factory settings and set up a new one. See Manual
http://us.edimax.com/edimax/mw/cufiles/files/download/manual/transfer/Wireless/BR-6424n/BR6424n-User-Manual_EN.zip
Press the reset button at the back of the router and
hold for 20 seconds to clear all settings.
Feb 21, 2013 | Edimax Computers & Internet
How to make password
Open Web Browser type in 192.168.2.1 in the address bar then hit enter. you should be prompt for user/password, and the default one are user: admin password: 1234
this will let you change settings. you will find the WIFI settings in the "General Setup" section.
i am attaching link to the user manual, if you like to dig in to the settings deeper:
http://www.edimax.com/images/Image/manual/Wireless/BR-6225n/BR-6225N_Manual.zip
Sep 02, 2012 | Edimax Network Br-6428ns Wireless N 300m...
Edimax br6204wg wan led doesn't light up and there is no internet connection
Hi yaminmagdi,
I believe that you are trying to get connected wireless using your Edimax Router, we may need to check some settings in your Edimax regarding the wan light not lit up and could be a possible reason why there is no internet connection.
1. First we will need to find an Ethernet cable for us to be able to connect your Laptop directly to your Edimax Router for us to be able to check and change any settings needed to enable your Edimax wireless connection. also make sure that the Ethernet cable is connected to the Ethernet ports behind the Router not the WAN port then the other end goes directly to your Router.
2. Once connected directly to your router from the Laptop open IE or any Browsers on your Laptop, in the Address bar type in 192.168.2.1 then press Enter this will prompt for a user name and password, User Name will be ' admin ' and the password should be 1234 unless you changed it.
3. Inside the Edimax setting page click on the Tab that says Wireless, check and see if the wireless is enabled if not then enable it or turn it on, after enabling / turning the Route ON save the settings by clicking on Apply or Save then it will prompt that the Router is restarting it will be 30 seconds to apply once the 30 seconds is up that should be done check your Edimax if the WAN light is already lit up, then you can try an connect Wireless from your Laptop.
I hope this helps.
Have a nice day.
Apr 03, 2011 | Computers & Internet
How to put a password on my edimax router?
Connect to your router.
Then go to internet explorer/firefox, etc
Type the address : 192.168.1.1
It will prompt for username and password,try "admin" for both or try "test" for both.
Router settings window opens, go to wireless option.
Enable Password Protect, select either wep/wpa and type the password.
Password is set.
Jun 30, 2010 | Edimax 4 Port Wireless AP Broadband Router...
Defalt code and password for a edimax br-6204wg
The default settings for your router are : 192.168.2.1 User name :admin and the Password is : 1234
Jun 18, 2009 | Edimax Computers & Internet
Connecting to locationfree for use of PSP
Is "locationfree" the name of your SSID at home? If so, the range is limited so you may have to connect to different network.
Jun 25, 2008 | Linksys Wireless-G WRT54G Router
Edimax BR-6104KP Router (BR6104KP) Logo
943 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
