Question about RCA Televison & Video
RCA 65 inch HDTV TV tries to turn on but the light flashes on and off three times (and will try to turn on again after 1-2 minutes) and repeat the flashing on and off three times. Is my favorite TV fixable?
  • asjdjj1 Jul 05, 2008
    D61W20
    Chassis ITC 222
    Thanks for the response!
  • RCA Master
  • 8,617 Answers
Yes what your describing is possibly a flyback which is very inexspensive and easy to fix. But I will need the model number of your RCA to be positive and tell you which flyback you need. So please respond to this same post with the model number and I will provide the proper info so you can repair the set without alot of exspense.
Posted on Jul 04, 2008
  • Sonny Berry
    Sonny Berry Jul 05, 2008
    Yes its definately the code for a flyback needing replacement. Your model uses flyback 259296 its available at the following link and they provide free online tech support with instant messageing to help you do the instalation. Here is the link.
    http://servicemanuals.vstore.ca/
My tv won't turn on anymore. The red light flashes 6 times then pauses for a couple seconds then starts flashing six times again. Just keeps doing it repeatedly
try unplugging the tv and waiting a minute and try it again if its still the same? It sounds like a Capicitor problem on the Power supply.
Dec 26, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Mitsubishi 65" LCD (1080P, DLP) keeps shutting down until it "warms up". After shutting down the power led flashes yellow for a minute or so, at which time I power it up again. This cycle repeats 1 to 4...
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV may require service.
Jul 27, 2010 | Mitsubishi LT-40133 40 in. LCD HDTV
I have a rca 52inch hd52w56 power light on front of set is solid,then flashes ten times,then solid again for a minute. repeats. tv will not turn off or on. ???? screen not on,no picture,no sound,nothing??
DM power board have some dead capacitors.Some capacitors bulge up,best indicatoin it dead,some u must used a multimeter to test.U know how to use a soldering iron and solder?Change all the DM power board capacitors,should get power back to ur tv.Try website Tv repair World.com maybe still selling this refurbish DM power board.
Mar 25, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 inch RCA HD/TV Does not turn on
Replace CP150 on the deflection board and that should take care of the problem since it starts once in a wnile if it didnt start ever then you would need the 259296 flyback and the CP150 Capacitor.
May 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52" GE-HDTV/Monitor. After the unit is turned off, it will not come back on-at all now. When I try to turn it on, the green light on the front of the TV comes on briefly, then goes off. I can...
replace CP150 CP114 and CP120 all three capacitors are available at the following link with free instructions they are listed under the RCA parts category which are the same ones for your GE TV.
Jan 17, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
1995 rca 52 inch tv...
Please post the model number of your RCA as usually its a bad flyback and start up capacitor when you get a 3 blink error code . But I can help you better if I have the model number of your set.
Oct 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture loss with standby lite flashing
If the standby light is flashing 4 times it indicates the TV is overheating because one of the 4 internal fans has totally failed or is not spinning fast enough. The fans start at about $35 and cost up to $65. Replacing 2 of the fans is quite easy. The other 2 require much more disassembly of the TV. I would suggest obtaining the service manual (not the owners manual) before trying to replace any of them.
Sep 23, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
Televison & Video Logo
675 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
